Interesting info on E85 and injector sizing
Old Aug 7, 2009 | 01:01 PM
Zooomer's Avatar
Supporting Vendor
We just did injector testing with 80's in Ryans car from 60's. Something interesting to note. If you have your car currently tuned for 60's on gas and you switch to 80# injectors, it's nearly a perfect tune when you go to E85 WITH NO PCM CHANGES! Woohoo!
If that's not easy, IDK what is.
Just passing along some free info to anyone who's interested.
http://www.zzperformance.com/cobalt_...1051&catid=174
Old Aug 7, 2009 | 01:04 PM
scott allen's Avatar
what all do you have to change to run e85. i have 79# injectors,well my mods are in my sig. can i just put e85 in the tank and then go get tuned or do i have to change some parts.
Old Aug 7, 2009 | 01:22 PM
ShortStack's Avatar
Looks like your talking about actual hardware.
Sorry.
Old Aug 7, 2009 | 01:24 PM
yes i did .he didnt say if you had to change anything just the tune would be ok.
ShortStack's Avatar
Changed my above post. My apologies.
Old Aug 7, 2009 | 01:26 PM
no your fine.lol i wonder if you have to change the fuel pump or anything like that?
Old Aug 7, 2009 | 01:27 PM
ShortStack's Avatar
I remember someone saying something about having to change.. or like coat something... but i might not be recalling it right.
Thats some pretty nifty information... This should be deleted after the first 200 views... then archived somewhere to where you can only search to find it...
Old Aug 7, 2009 | 01:29 PM
BLAZIN07SS's Avatar
I'm too JDM for you
just the tune needs to be changed. the fuel system can support e85 just fine
Old Aug 7, 2009 | 01:31 PM
are you for real? if so that would be cool .now i just need to find e 85. wonder how much hp you would gain with the e85 and a good tune to take advantage of it.
ShortStack's Avatar
Actually, the the last modified mag i picked up.. big article about ethanol... tells you EVERYTHING you need to know... explains how it works.. how much extra hp was picked up...
Old Aug 7, 2009 | 01:32 PM
BLAZIN07SS's Avatar
I'm too JDM for you
just know that fuel mileage will suffer, not readily available nationwide, and i hope you like the smell of corn oil
Old Aug 7, 2009 | 01:37 PM
Maven's Avatar
Big time, usually on the order of 20-25% or more.
Old Aug 7, 2009 | 01:43 PM
ShortStack's Avatar
Originally Posted by Modified Magazine
From our testing with the readily available e85 fuel we now use in our time attack Impreza L. which is about 105 octane, weve found its not quiete as high as knock resistance as the 116 leaded race fuel. This might lead you to think that the car would have to be someone dumbed down, but what ethanol really shines at doing is lowing the cooling charge temp. With ethanol, we were able to go beyond MBT (Minimum best timing, the lowest value of ignition advance that produces the maximum power) without knocking. On the 116 leaded we actually ran out of effective knock prevention prior to reacing MBT, but we were able to go well beyond with e85 illustrating its charge cooling properties.
There we go!
Does also mention..
"If the car is being used to commute 50 to 60 miles per day and driven hard on the weekends, you have to decide if the power is worth it, given that your engine will consume about 30 percent more e85 getting from point a to point b.
Old Aug 7, 2009 | 02:09 PM
2K5SS/SC?'s Avatar
Interesting....
Old Aug 7, 2009 | 02:12 PM
i dont drive my car that much,i think of the cobalt as just a toy.its a 07 and only got 8200 miles on it.so the gas milage wont bother me a bit . my old nova only got 5 mpg so im all for it.
Old Aug 7, 2009 | 05:54 PM
Zooomer's Avatar
Supporting Vendor
I was saying that if you had a setup, like a stage 2 kit or something and you were running 60# injectors as a lot of people are; then you could install 80# injectors and run E85. That would be the ONLY change and you'd be tuned correctly.
Nothing in the car needs to change other than fueling to run E85. Stock pump/lines, etc are just fine.
Downsides are losing 1/4 of your fuel economy and harder to find fuel. Benefits are no KR, safety, a corn smell, lower fuel costs in some area and 5% power gains.
Yes, you read that right. 5% power gain over 93 octane. So a typical stage 2 car in the 240-250 range is going to add 10-15WHP
Old Aug 7, 2009 | 06:06 PM
ebristol's Avatar
Miles per gallon goes down along with cost per mile.
E-85 = $1.799/g
Premium = $2.79/g
I am going to check you on this.
BRB
Old Aug 7, 2009 | 06:18 PM
Area47's Avatar
Rent me! per hour
please keep in mind. not everyone runs the same fuel map/injector control scaling.
Old Aug 7, 2009 | 06:47 PM
ebristol's Avatar
Well with my fuel map/injector control scaling for 60s my car it ran a touch lean on a tune dialed in to 11.7 - 11.8 afr in PE on premium.
I was seeing actual afr readings of 11.9-12.2 on E85.
So just installing the 80# injectors and running E85 will get you very very close.
I still don't know what the optimal E85 fuel readings (calculated to gasoline) are. In my actual E85 tune I am running 11.5 afr just to be safe.
Old Aug 7, 2009 | 07:35 PM
so if i have 79#injectors now ,to go e 85 i would need bigger injectors?
Old Aug 7, 2009 | 08:01 PM
mrsilent13's Avatar
cool this is good to know...now to find some 80#...lol
Old Aug 7, 2009 | 08:05 PM
Darkmanx's Avatar
hmmm
Old Aug 7, 2009 | 09:18 PM
StreetLC's Avatar
So you're saying people with GM stage 2 can swap the 42's to 80's and run e85 just fine? cause if this the case im doing that **** ASAP....i live in the midwest so e85 is everywhere.
Old Aug 7, 2009 | 10:52 PM
ebristol's Avatar
I am running the Siemens 80# injectors on E-85. I think you will be ok with the 79s
I don't think he is saying that.
What I think he was saying that if your car is tuned for 60# injectors you can simply install the 80# injectors and switch to E-85 and your car will run fine without needing to change your tune.
Reason being, that the car has to run more fuel with E-85. So the 80# injectors on E-85 work well with the tune from 60# injectors on gasoline.
I found is that it is very close.
Old Aug 7, 2009 | 11:10 PM
Sw4y1313's Avatar
That would be a cool upgrade for myself. Should help me break 300whp. Dunno if its worth it having to buy the larger injectors and waste more gas though.
