Intermittent "brake" warning light?
Old Jun 21, 2010 | 05:58 AM
Omega1x's Avatar
Hey guys, just wondering if anybody knows what could cause this. I will be driving at highway speeds(60MPH) with cruise on and my "brake" warning light will pop on for no reason. It is very intermittent and hasn't happened recently till tonight. If anybody has info on this please let me know. Thanks.
Old Jun 21, 2010 | 06:57 AM
selfinfliction's Avatar
pop the console off and check the switch on the ebrake. mine did that when the parking brake cables needed adjusted
Old Jun 21, 2010 | 04:36 PM
SunburstSS's Avatar
also check ur brake fuild mine was giving that when my rear caliper was leaking :x make sure ur not low on that or u would be in soooo mucho trouble
Old Jun 21, 2010 | 07:03 PM
Dainslaif's Avatar
This happened to me as well.
Old Jun 21, 2010 | 07:57 PM
Omega1x's Avatar
Alright thanks. Will have to check both things.
Old Jun 21, 2010 | 07:58 PM
Corvettespirit's Avatar
GRABBER BLUE MUSTANG GT
2005 MY? check this!!
#05-08-49-019: Brake System Warning Light Comes on Intermittently (Reprogram IPC) - (Jun 22, 2005)
Subject: Brake System Warning Light Comes On Intermittently (Reprogram IPC)
Models: 2005 Chevrolet Cobalt
2005 Pontiac Pursuit (Canada Only)
Condition
Some customers may comment that the brake system warning light comes on intermittently. The brake light will illuminate for 2 to 3 seconds, then will turn off and may never illuminate again. The vehicle should exhibit no braking concerns at all.
Correction
Important: Programming the IPC must be done PASS-THRU ONLY.
Inspect the brake fluid level and the operation of the parking brake signal switch. If normal, technicians are to reprogram the IPC with an updated software calibration. This new service calibration was released with TIS satellite data update version 6.5 available June 13, 2005. As always, make sure your Tech 2Ž is updated with the latest software version.
The customer should be thoroughly questioned to determine if a warning chime accompanies the brake system warning light, and if the BRAKE FLUID or PARKING BRAKE messages are displayed on the DIC when the condition occurs. The condition being discussed does not include any DIC message or warning chime. If the customer reports hearing the warning chime or the DIC messages, then further diagnosis is needed, searching for unwanted inputs from the parking brake switch signal or brake fluid switch signal.
I hope this answer your question!!
Old Jun 21, 2010 | 08:00 PM
WVsuperSS's Avatar
mine has been doing that now for a while, but now its staying on... the dash say "brake fluid"
Old Jun 21, 2010 | 08:27 PM
SunburstSS's Avatar
Exclamation
check ur brake fluid maybe
Old Jun 21, 2010 | 11:14 PM
Omega1x's Avatar
lol the other guy's problem is obvious.
But thanks for that reprogram post. That's most likely my problem. Just need a reprogram. Cuz the parking brake works right and the light comes on when it should and brake fluid level is fine.
Old Jun 22, 2010 | 09:29 AM
insylem's Avatar
As long as it doesnt say "FUEL RAN BRAKE"
Old Jun 22, 2010 | 01:49 PM
CobaltSS313's Avatar
Mine has been coming on/off since I've gotten the car, I've known about the problem but didnt know there was a fix for it, although it hasnt come on for some time now so I'm not to worried about it.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
