issues...
Old Feb 6, 2011 | 02:04 PM
chris88z24's Avatar
I love how the OP mentions how he JUST went from pump gas to E85, yet you all are mentioning everything BUT the tune.
Old Feb 6, 2011 | 02:09 PM
Chevycobaltss3's Avatar
^^^^^^ u read some posts down the row it states he tuned for it lmao so ummmmmmmmmmmm im a tuner so i made sure to look...
page one, states he got his tune revised. i doubt his tuner is stupid and tuned him for gasoline.
op wuts your afrs at idle, should be like 11ish for e............
Old Feb 6, 2011 | 04:20 PM
G11's Avatar
G11
well we have been trying to play around with it a little bit to fix some start off problems... but i believe it is around 11-13 i can't remember atm
Old Feb 6, 2011 | 04:24 PM
well e85 needs to be at 11ish which is around stoich gasoline is 14.7 so make sure and let me know
Old Feb 6, 2011 | 04:47 PM
chris88z24's Avatar
You can't just switch from pump to e85 and change the tune one time and call it a day.
Old Feb 6, 2011 | 04:51 PM
no freakin duh bro, ive prolly dealt with tuning , e85 and alot more then u so i know wut im talking about........ So with me saying this he states he updated his tune. i see your point and i belive you but this is not his issue, it could be tune which i am leaning toward if his tuner is a idiot and doesnt think on what to do or what to change to get the e85 to stoich and to get a good safe burn
Old Feb 6, 2011 | 05:15 PM
chris88z24's Avatar
Yeah you seem like a clever book of knowledge so I'll just subscribe and see what happens. You know, with the tune, once he has it re-calibrated correctly.
Old Feb 6, 2011 | 05:18 PM
yeah im leaning toward tune after he told me his idle is 13 with e85.... Wtf right.... So we shall see, if his car is correctly calibrated for e85 and only e85 then the car will run great. but if not it can be doing this
Old Feb 6, 2011 | 05:59 PM
InfraRedline's Avatar
Well if he is reading the AFR on a normal wideband it should still idle around 14.7. If he has one that can be set to E85 values then it will idle at its actual AFR, or if he has HPT setup to convert the wideband reading into E85 AFR. But say he is using an AEM EUGO it will read just like gasoline the whole time
Old Feb 6, 2011 | 06:02 PM
Karlen89's Avatar
Originally Posted by srt-10
ic pump fails, your iat2 goes up, you get knock retard and that would cause you to loose your power.
It's not 100* outside, so I highly highly doubt his iat2's would be up high enough to cause kr
Old Feb 6, 2011 | 06:48 PM
  #36
chris88z24's Avatar
I just set my PE EQ ratio to 9.5 why does my car stall out when I floor it helpppppp!!! zomg.z
Old Feb 6, 2011 | 10:51 PM
  #37
wut you set you pe to 9....... ummmmm set your pe enrchemt to wut ever you want your car to run say if you are running a 14.7 stoich whicch i hope u are and you want your afr to be at 11.3 set your enrichment value at 1.3,,, and your value rate at 1.5 for the quickness of the ecm to get your p.e on the commanded afr
Old Feb 7, 2011 | 04:00 PM
  #38
chris88z24's Avatar
You really tune cars, huh?
Old Feb 7, 2011 | 04:12 PM
  #39
Pyros777's Avatar
Have you tried switching back to gas + your gas tune and seeing if the condition still exists?
Tuning for e-85 really isn't that hard, so I'm curious to see if your car goes back to being fine when you switch back to 91/93.
Old Feb 7, 2011 | 06:26 PM
  #40
yes i really tune cars, and tuning for e isnt hard like pyro said jsut takes more time u can say
Old Feb 8, 2011 | 06:29 AM
  #41
G11's Avatar
G11
well changing out the o2's today to see if it runs better... and i just have an AEM UEGO... and to clarify i couldn't remember where it sat...i said 11-13 but i checked today and it was sitting at 10.8-11.2 most of the time
tuner says on last datalog that the front o2 was acting up the whole time i was driving it...only was able to barely hit WOT once and after that if i touched the gas much more than 1/8 of the way it would just putt along...
Old Feb 8, 2011 | 11:13 AM
  #42
k if the front 02 is a bitc* rigt now i can see he issue happening but id also seeour wideband messing up as well/ was the milivolts just not changing alot?
Old Feb 8, 2011 | 05:17 PM
  #43
G11's Avatar
G11
no idea honestly haha!
Old Feb 8, 2011 | 06:52 PM
  #44
srt-10's Avatar
i've seen cars get knock retard in below freezing temps in Celcius before. Yes ambient temps have a roll in it, but isnt always the factor if you are getting KR.
Old Feb 9, 2011 | 12:38 AM
  #45
temps do have alot to do with kr............ If the ambient temp is -20 the car will add timing not only for cat warmup but for performance results and ect. if the car has been treated like it should with its tune, meaning spark adders ect , meaning theyve been taken out of the tune then it wont be an issue.
Old Feb 9, 2011 | 09:57 PM
  #46
chris88z24's Avatar
Yeah, I wouldn't go zeroing out those tables if the car is to be driven year-round, in drastically varying altitudes and temperatures.
Old Feb 10, 2011 | 12:43 AM
  #47
ummmmmmm ok u need to delete spark adder tables buddy.
Old Feb 12, 2011 | 10:58 PM
  #48
G11's Avatar
G11
update...so intalled the new o2 sensor and still runs like ****...mainly just getting the lean code now... could it be my fuel pump rewire kit?
Old Feb 13, 2011 | 12:11 PM
  #49
it could but check the fuel pressure under boost and at idle, should be around 45-55 i think for a for a good fuel pressure under idle..... check for a exaust elak, could be tune as well wut r ure fuel trims as well.
Old Feb 13, 2011 | 01:35 PM
  #50
ssforlife's Avatar
my ic pump went bad and my iat2 wasnt exceeding like 140 i think and it didnt cause enough problems to make my car never died to idk if this would cause it
