issues...
well i just went out to start it and it maybe runs for five sec then dies... i try giving it gas and it makes it die faster...i know i have pressure for sure i have try many different things and get the same results...i don't have any exhaust leaks, i have checked that a couple of times as well
so i figured it out...it was my maf sensor. the only stupid thing is i had a buddy come over that has an 06 ss/sc and we swapped mafs. well he started it up and it ran fine then we took it on the freeway and did a wot and it ran fine....next we tried mine, started up kinda hard and then idled funny for a min then idled fine...drove it around my neighborhood and it was driving a little funky then got brave and tried the freeway with wot and omg it actually runs!
i can't believe it was causing this much grief and the stupid thing is us switching those around and his runs mine too...don't get it at all
i cleaned that thing like 3 or 4 times too along with unplugging it and plugging it back in...so im not sure what it was
not saying that you didn't...i cleaned and unplugged it and plugged it back in and nothing....so i decided to swap them and it worked....only thing that i don't get is how is my buddies car running fine when mine wasn't with the same maf
connection issue possibly............ and also his car has his ltft learned a little too so that helps a tad.. If your maf truly is bad then his car will end up running like ****.
