Japeatr's knocking at the track rebuild thread
Old Jun 4, 2014 | 06:40 PM
JapEatr's Avatar
South Central *********
So Lone Star Bash was fun times!
Had traction and shifting lockout issues but managed a 13.73 @ 113.6mph on street tires
Based on trap speed, car should be low 12s with a granny 3rd gear shift
After about a dozen runs on spray and a few without spray, I shut the car down to have some beers while DFWGMElite was cleaning up the event. When I fired it up to put it back on the trailer, the engine had a nasty rod knock.
So I dragged it home on the trailer, pulled VC...nothing out of the ordinary, pulled the oil plu...bingo this huge metal flake was on the magnetic drain plug....FML
Time to rebuild again....
Pulled the block, and removed the head, spun number 3 rod bearing. Ruined the crank and all the bearings. Rods need reconditioning
Cameo of Taintedred07s car
FAQ:
I was spraying nitrous in 2nd and 3rd.
Q: How much boost was it running?
A: 27psi
Q: how much timing?
A: 26*
Q: How high did you rev?
A: 8,000rpm
Q: how much nitrous?!
A: 75 wet starting at 4500 rpm amd going until 7500 rpm
Mods:
ZZP Girdled Gen 1 Block
Diamond 9.5:1 Pistons (may switch to 10.5:1 for the rebuild)
Oversized wrist pins
Total Seal Rings
Pauter rods
ARP Rod bolts
ARP Head Studs
Ported Head
ZZP Stage 2 cams (now sold, going with a custom set of cams)
ATI Super Damper
ZZP 82# valvesprings
(Just Deleted Balance Shafts)
TVS with 2.6" pulley
Dual Pass/Opt B
Stage 2 Belt
Oversized Tensioner Pulley
Relocated Stock HE
ZZP3" intake
CIA Midlength Header with 1 3/4" primary and custom downpipe
Hahn 3" Exhaust
ID1000s (for sale)
Powell Custom Fuel System with Surge Tank and Bosch 044 inline pump
DW300 lph pump in tank
OTTP Return Style Fuel System
NX 75 wet shot with MSD window switch and purge
So the plan is to Resleeve with Belvedere spun moly sleeves, to compliment my girdles block
Bore sleeves for new Diamond 10.5:1 pistons (I believe I had too much piston to wall clearance on the original Diamonds)
arp timing bolts (have)
Electric Water Pump
Delete Balance Shafts (Done)
BIG CAMS!
190# injectors
2.4" TVS Pulley
Solid lash adjusters
Jet Nitrous for 100shot wet
Any thoughts...
Old Jun 4, 2014 | 07:01 PM
JapEatr's Avatar
Paid Jeff for a new crank today
Old Jun 4, 2014 | 07:34 PM
574's Avatar
574
FIC injectors?
Time frame?
Old Jun 4, 2014 | 07:35 PM
TStone's Avatar
More NAWZZZZZZ
Old Jun 4, 2014 | 08:02 PM
ItalianJoe1's Avatar
Wait so the car went 13.7 and blew up? I don't know if I'd have it in me to rebuild after that
It took me a while to get over the fact that I blew the side of the block open on the yellow car. GLWRebuild, hopefully you have better luck with the bearings this time around. Any over-revs happen while at the event?
Old Jun 4, 2014 | 08:36 PM
JapEatr's Avatar
Regarding the low ETs. I was not there for glory numbers ...lol was more tuning the setup
I was on 225/40/18 KDW2s (my street setup) launching to keep wheel spin in check
My biggest hurdle with the ET was the car did not want to shift into 3rd at 8k.
I had turned the stock flywheel and I think that thickness was causing issues with clutch travel on my GMPP
I had a built motor, just found a weak link in it, rebuild and move on... part of racing
The pauter rods were out of Paul (06BlackG85SS) turbo car. ZZP installed them when they assembled the Girdled block. I think the clearances may not have been perfect
Only bummer is I killed my crank with extended keyway
Old Jun 4, 2014 | 08:54 PM
Josh@ottp's Avatar
Match the pistons to the cam and don't go with off the shelf diamonds for the build. You will melt or crack a ring land.
Old Jun 4, 2014 | 09:36 PM
JapEatr's Avatar
I think I'm going with your stage 4s, but I need them degreed that will negate the need for the adj cam gears
Old Jun 4, 2014 | 09:46 PM
Josh@ottp's Avatar
Cam gears are how you degree them. There is no other way.
Old Jun 4, 2014 | 10:00 PM
JapEatr's Avatar
Are Bates and GMPP the only options for cam gears?
Old Jun 4, 2014 | 10:06 PM
Kahless's Avatar
jeff sells crank?
Old Jun 4, 2014 | 10:16 PM
taintedred07's Avatar
Jeff sells everything lol Japs car was a beast on the street even with a 50 shot
Old Jun 4, 2014 | 10:19 PM
lsjion's Avatar
I think you had too much timing in it with the shot.
May consider pulling some next time around.
I'm sure IAT's weren't too friendly either
Old Jun 4, 2014 | 10:51 PM
JapEatr's Avatar
Was a beast at the track but it took me 2 seconds to get it into 3rd gear
Old Jun 4, 2014 | 10:54 PM
mrbelvedere's Avatar
I believe bates makes the gm cam gears
wot box will fix that
Old Jun 4, 2014 | 11:30 PM
Bluelightning's Avatar
Got Bewst?
Sorry to hear man. What was your ET on spray? Or was the 13.7@113 on spray?
Old Jun 4, 2014 | 11:42 PM
JapEatr's Avatar
Traction, shifter lockout, and poor DA at the track
All my ricer excuses lol
Old Jun 4, 2014 | 11:49 PM
Got Bewst?
Baaad day at the track and you popped your motor. I'd straight up cry lol. Well sub'd for better luck this time around!
Old Jun 4, 2014 | 11:53 PM
JapEatr's Avatar
I brought it to the track on a trailer pulled by my twin turbo ford truck
So i came to lay it down or break trying
Old Jun 5, 2014 | 12:00 AM
LNFTX's Avatar
Props man awseome attitue about the whole deal cant wait to see what you come up with next I usually end up learning something new when you update your build but sorry to hear it didnt go well this time around
Old Jun 5, 2014 | 12:04 AM
JapEatr's Avatar
Appreciate it man. To be honest the motor had 3300 miles on it, first time to the track with the new setup, raced it a few times on the street to dial in the fuel system
Takes time to work out all the weak links
Old Jun 5, 2014 | 12:40 AM
Damn dude. Awesome that you are still pressing forward! And its gonna be even nastier this time around!
Any footage of the 3300 miles?
Old Jun 5, 2014 | 12:47 AM
JapEatr's Avatar
I have some vids of my nitrous on youtube. Need to get the vids off my camera that is on the car downloaded lolz
Old Jun 5, 2014 | 01:28 AM
Spawne32's Avatar
what kind of bearings were you running?
