just another build thread
(thought i would organize my threads) got bored with everything as usual... build number 4006 in progress here now. doing this a little different than before.
just doing this to keep me occupied while i save some extra funds for a twincharge kit
P&P'd head with oversized ferrea valves and 78# springs ^^^check
ported blower, external polished silencer holes blocked ^^^check
ported throttle body ^^^check
zzp stainless header/downpipe (aluminunized ceramic coating) ^^^check
magnaflow 2.5" cat back ^^^check
60#'s -2.8" w/ ottp tune (also have intense stange 4 tune) using this as a starting point until i get some dyno time ^^^check
a/f system ^^^check
act 6 puck clutch kit with lightweight flywheel ^^^check
G85 LSD trans ^^^check
ottp cabs ^^^check
tc struts ^^^check
tc engine/trans mounts ^^^check
diamond pistons (plated not coated) -- ordered already
ebay intake (cause they're all the same to me) ^^^check
dual pass (no option b) ^^^check
cometic
arp's
neutral balance shafts
polished LIM for a bit better cooling ^^^check
after coatings
before and after
head
clutch
blower after scrubbing it initially... still have a couple hours of work to go
mounts
struts
exhaust
blower
throttlebody
g85 trans
a/f system ^^^check
ottp cabs ^^^check
tc struts ^^^check
cometic
arp's
after coatings
before and after
head
clutch
mounts
struts
exhaust
blower
throttlebody
g85 trans
for now i'm just being lazy and putting the bolt on stuff. when i drop the engine for the trans swap we'll also do the pistons and head at the same time..
not really that expensive... i think under $4k for everything and that includes trans/clutch/head+porting etc...
Last edited by selfinfliction; Dec 24, 2009 at 08:39 AM. Reason: Automerged Doublepost
yeah i had a question.. the TOB has been the same correct? I found a new TOB with a mfr date of '07 on the shelf here, guess i bought it for one of my other projects a couple years ago.
the slave i know is changed, but not sure on the TOB... any info would be appreciated
ok thanks man... we're going to drop the engine maybe the end of jan/feb but the turn around time on the plating is ~4 weeks so i gotta get them shipped out to that shop soon.
good deal, should be after the holiday...due to postal delays
/end thread jack
Selfinfliction, car is lookin awesome man, cant wait til its together and all polished like that
/end thread jack
depends on the step height of the flywheel. the clutch set up i plan on running it is required to use it, but then again. it's a heinz 57 kit.
you should be ok either direction you go. you may want to consult act to make sure
forgot about this thread... recently just ordered:
selling ported & welded M62
bought OTTP stage 3 kit
sold the magnaflow catback
bought corsa touring catback
sold AEM UEGO
bought PLX DM-100 OBDII gauge with wideband controller
just bought today a set of the new Darton MID sleeves
went ahead and got the sleeves cause not sure how long the motor will last with the harrop. plan is once everything is rebuilt to run meth and bump up the boost to about 25 psi
sold AEM UEGO
