just another build thread
Old Dec 23, 2009 | 11:39 PM
selfinfliction's Avatar
(thought i would organize my threads) got bored with everything as usual... build number 4006 in progress here now. doing this a little different than before.
just doing this to keep me occupied while i save some extra funds for a twincharge kit
P&P'd head with oversized ferrea valves and 78# springs ^^^check
ported blower, external polished silencer holes blocked ^^^check
ported throttle body ^^^check
zzp stainless header/downpipe (aluminunized ceramic coating) ^^^check
magnaflow 2.5" cat back ^^^check
60#'s -2.8" w/ ottp tune (also have intense stange 4 tune) using this as a starting point until i get some dyno time ^^^check
a/f system ^^^check
act 6 puck clutch kit with lightweight flywheel ^^^check
G85 LSD trans ^^^check
ottp cabs ^^^check
tc struts ^^^check
tc engine/trans mounts ^^^check
diamond pistons (plated not coated) -- ordered already
ebay intake (cause they're all the same to me) ^^^check
dual pass (no option b) ^^^check
cometic
arp's
neutral balance shafts
polished LIM for a bit better cooling ^^^check
after coatings
before and after
head
clutch
blower after scrubbing it initially... still have a couple hours of work to go
mounts
struts
exhaust
blower
throttlebody
g85 trans
Old Dec 23, 2009 | 11:49 PM
spike's Avatar
looks like u have a good start!!
Old Dec 23, 2009 | 11:52 PM
06_SIC_SS's Avatar
mmm looks like fun to todd!!!
Old Dec 24, 2009 | 12:18 AM
G11's Avatar
G11
wish i had money and time ha!
Old Dec 24, 2009 | 12:19 AM
06_SIC_SS's Avatar
the head sitting next to me isnt nearly as pretty as urs.. not yet atleast lol
Old Dec 24, 2009 | 08:39 AM
for now i'm just being lazy and putting the bolt on stuff. when i drop the engine for the trans swap we'll also do the pistons and head at the same time..
not really that expensive... i think under $4k for everything and that includes trans/clutch/head+porting etc...
Last edited by selfinfliction; Dec 24, 2009 at 08:39 AM. Reason: Automerged Doublepost
Old Dec 24, 2009 | 10:21 AM
G11's Avatar
G11
oh nice! thats not bad at all!
Old Dec 24, 2009 | 10:39 AM
jimbos'ss's Avatar
might think about getting the lnf slave cylinder while your at it.
Old Dec 24, 2009 | 11:56 AM
yeah i had a question.. the TOB has been the same correct? I found a new TOB with a mfr date of '07 on the shelf here, guess i bought it for one of my other projects a couple years ago.
the slave i know is changed, but not sure on the TOB... any info would be appreciated
Old Dec 24, 2009 | 12:59 PM
jimbos'ss's Avatar
the slave and TOB are one and the same on the cobalt. they integrated them into one piece units. if its got a green rubber sleeve its lsj, no sleeve its lnf
Old Dec 24, 2009 | 05:44 PM
ah ok... yeah it's green, need to get a new one then
Old Dec 24, 2009 | 06:57 PM
06blackg85ss's Avatar
btw pistons and whatnot are on the way to ya.... usps finally showed up to pick up everything today after 3 missed pickups and about 5 phone calls to the main office lol.
Old Dec 24, 2009 | 07:12 PM
JapEatr's Avatar
South Central *********
mine too?
Old Dec 24, 2009 | 07:14 PM
slowswap's Avatar
Should be a solid build!
Old Dec 24, 2009 | 07:19 PM
ok thanks man... we're going to drop the engine maybe the end of jan/feb but the turn around time on the plating is ~4 weeks so i gotta get them shipped out to that shop soon.
Old Dec 24, 2009 | 07:32 PM
Originally Posted by JapEatr
mine too?
check didn't show up yet, but those rods are sitting wrapped up in my drawer at work ready to go
Old Dec 24, 2009 | 07:56 PM
JapEatr's Avatar
good deal, should be after the holiday...due to postal delays
/end thread jack
Selfinfliction, car is lookin awesome man, cant wait til its together and all polished like that
Old Dec 24, 2009 | 08:08 PM
Area47's Avatar
Rent me! per hour
the throw is a tad bit longer on the lnf ones vs the lsj's.
Old Dec 24, 2009 | 08:22 PM
so it's still safe to use?
Old Dec 24, 2009 | 08:31 PM
Area47's Avatar
Rent me! per hour
depends on the step height of the flywheel. the clutch set up i plan on running it is required to use it, but then again. it's a heinz 57 kit.
you should be ok either direction you go. you may want to consult act to make sure
Old Dec 24, 2009 | 08:56 PM
ah ok so if their kit works on the lnf it should work on this one?
Old Dec 25, 2009 | 12:29 PM
Area47's Avatar
Rent me! per hour
yepo. it works with the gm clutch kit as well. if the step height between the two flywheels is factionally different you'll be good either direction.
Old Dec 25, 2009 | 12:37 PM
jimbos'ss's Avatar
beat me to it. and so far it doesn't leak.
Old Feb 1, 2010 | 12:54 PM
forgot about this thread... recently just ordered:
selling ported & welded M62
bought OTTP stage 3 kit
sold the magnaflow catback
bought corsa touring catback
sold AEM UEGO
bought PLX DM-100 OBDII gauge with wideband controller
just bought today a set of the new Darton MID sleeves
went ahead and got the sleeves cause not sure how long the motor will last with the harrop. plan is once everything is rebuilt to run meth and bump up the boost to about 25 psi
Old Feb 1, 2010 | 01:03 PM
ralliartist's Avatar
looks like a lot of fun! keep us updated!
