Just a cool thought....
this is just a thoughtand Im here just to see if something like this would work so No one flame,
I read some were on here that you can use mobil 1 5w30 fully synthetic oil for the supercharger oil, not sure if this is correct or not, but! if it is would it be a good idea/project to tap off some pressureized oil drill and tap into the gear secotion of the supercharger, drill and tap it out and run the return to the oil pan, and regulate it some how if neseccary, kind of like a turbo, I know for guys like me with the small pulleys and such we have to change the oil more often then you would stock,
so my questions are
can the mobil 1 5w30 fully synthetic be used in the supercahrger?
and if soo would haveing pressurized constent feed oil a good idea?
just think it gets changed everytime you change your oil and I change mine ever like 2500 miles or once every few weeks at the most,
please NO FLAMING !!! justa thought and if you all think its a good idea ill be the first to experiment with it I have the tools and money for this soo.
lets see what yall think, I have no idea if this is good or bad soo please be nice,
shane
so my questions are
shane
Your idea means well, but think about it in a practical sense.
What are you going to gain? The blower will already last as long as the car or longer on its current oiling system. Is it really worth spending time, money, complexity, and engine bay room on an external oiling system that will make it last 500,000 miles?
FYI, most centrifugal blowers use exactly the kind of oiling system you're talking about. So in some applications it is nessesary or worth it. I'm guessing because the gear boxes in those see signifcantly higher RPM.
and if wouldnt take that much room at all just the oil feed and return lines
soo it sounds like a good idea or no?
and is the oil the same?
come I want more opinions here! everyone chime in!
It would be kind of hard to make a kit to oil the bearings seeing as to how they use high heat GREASE .. good luck pumping grease through there tho
He said it could possibly work on mobil 1 and someone else in another thread was asking about where to find OIL for the blower. Just keeping the gearbox better cooled and lubed should keep excessive heat from building up on any wear surface.
it might even help keep heat down a lil? maybe? haha
yeah thats what I was thinking instead of the oil just sitting in there getting hotter and hotter, it would have oil flowing through it too keep it lubed (haha) and keep the s/c temps down a lil
I wouldnt worry about it.If your that paranoid about the oil,flush it out every 50,000 miles or so.Aslong as your not using a pulley the size of a bottle cap,you shouldnt worry about the bearings seizing up on you,lol.
Im not parraniod, I just thought I had a good idea thats all
Well I've also heard about using synthetic oil in eaton blowers. I've heard people argue both sides of the story too. As a matter of fact my oil in the blower was VERY VERY low and the only thing I had laying around was used supercharger oil from an m90 and some mobil 1. The mobile one went in (equivilant to over one bottle of the supercharger oil), and I've been running it that way for a couple thousand miles. I'm probably going to be picking up a bottle of supercharger oil for it and removing some of the stuff I put in (if I ever get around to doing it). I don't think it will cause any major problems or anything though. On a side note your idea is pretty cool. It won't be too hard to do. Just put a "t" fitting where the oil pressure sending unit is for the pressure side. Drill/tap a couple fittings into the blower, and drill/tap a hole in the oil pan for the return. The only other concern I would think of is can the seals in the blower handle 40+psi oil. I guess one way to find out!
