Just got back from the dyno
Old Apr 28, 2010 | 08:13 PM
Bl4des's Avatar
went to smg to get my car tuned and dynoed
i was told my 3in is hurting my car i think i am going to but the 2.5 downpipe and go back
Old Apr 28, 2010 | 08:16 PM
Zach06CobaltSC's Avatar
Now we see the graph =D
andrew97's Avatar
what kind of power did you make cant see it?
Old Apr 28, 2010 | 08:17 PM
ecot3c inside's Avatar
really?? crap, I just bought a 3in off of japeater, if it doesn't work good with your mods, it defiantly won't work with mine.
Bl4des's Avatar
dyno sheet is up now
Old Apr 28, 2010 | 08:20 PM
The 3 inch isn't killing your performance. With the mods you have you can get more out of it. What afr are you running, how much timing, any supercharger/torque restrictions, etc?
Old Apr 28, 2010 | 08:22 PM
slowswap's Avatar
I've seen more horsepower out of a 2.8 car with stock exhaust.
3" is to large until you break 300 whp mark.
Old Apr 28, 2010 | 08:48 PM
Bl4des's Avatar
i think it is like 26 or more degrees of timing and air fuel is about 11.6
Old Apr 28, 2010 | 08:51 PM
EXsoccer1921's Avatar
its not the exhaust, its the tune. i made 23whp and 12wtrq more than that with your mods(different brands) minus the dual pass and on a 2.8
iirc 07MetallicSC is tuned by them on a 2.8 and he put down like 230s
Old Apr 28, 2010 | 08:54 PM
Caligula's Avatar
At what point is a 3" all the way, a good thing?
Old Apr 28, 2010 | 08:57 PM
well with a tvs, its basically manditory. for me, i put down 273/250 with:
3" intake
2.8
60s
ottp h/e
meth
header w/ 3" exit
3" catted downpipe
3" catback
Old Apr 28, 2010 | 09:00 PM
ziggity's Avatar
Could lean it out a bit more.
Old Apr 28, 2010 | 09:01 PM
Bl4des's Avatar
it was rain slightly wail we were tuning, so it was very humid. i don't know how much of a difference it would make but the car runs a lot smother and pulls harder then it did with the trifecta tune. also it was dynoed in 3rd gear so we could keep the car cooler to tune it
Old Apr 28, 2010 | 09:05 PM
yeah you won't really see any difference dynoing in 4th vs 3rd. people just choose the lower cause the wheel speed is way too high in 4th at the end of the run. i'd look around at getting a custom tune from someone using hpt that knows what they're doin
Old Apr 28, 2010 | 09:43 PM
Bl4des's Avatar
i like how you say find someone who knows what he is doing
fred is one of the best tuners around
Old Apr 28, 2010 | 10:03 PM
Blown07SS's Avatar
damn only 250. I got zzp stage 3 with 2.8 pully and badmab header on stock exhaust with torque damper and ported and pluged blower if I dont get around 260 or more im gettin ported head, cams and so on... but im going to get a dyno soon and compare. I was told dont go 3" unless you go turbo
Old Apr 28, 2010 | 10:05 PM
Bl4des's Avatar
you wont get 260 on a zzp tune
Old Apr 28, 2010 | 10:16 PM
Cefaln452's Avatar
hahahah <3 that **** ^^^^
Old Apr 28, 2010 | 10:26 PM
shadowfaxss's Avatar
You sold your Magnaflow and got the three inch......I still believe the old rule of thumb......an inch for every 100 horse power.
Old Apr 28, 2010 | 10:39 PM
Bl4des's Avatar
here is a vid. this way only the second pull. meth not on and it is a 4th gear pull
http://www.youtube.com/watch?v=8yOcu6QVg9Y
Old Apr 28, 2010 | 11:34 PM
then prove me wrong and go dyno on a day it hasn't rained. low humidity. and see what you do. cause honestly you should be in the upper 260s if not 270s. and torque should be around 250
Old Apr 28, 2010 | 11:53 PM
Bl4des's Avatar
how much are most boost are most people getting with a 2.7 and 3in exhaust i only get to a little over 15lbs
Old Apr 28, 2010 | 11:59 PM
BlackBaltSw's Avatar
What are your supporting mods? Sounds WRONG, my have a full 3" and i see upwards of 18
Old Apr 29, 2010 | 12:14 AM
Bl4des's Avatar
zzp s3 heat exchanger, gm dual pass, 75% meth 25% water 7gph nozzle, raw 3in intake, zzp midlength header and downpipe catless 3in, hahn 3in catback
Old Apr 29, 2010 | 12:18 AM
elite_Cyborg's Avatar
i doubt that the 3 inch is hurting you, since when does back-pressure matter on a blower car?
