Just got my car back together.. p0017
Old Apr 10, 2011 | 11:07 AM
boost_junkie16's Avatar
So I just swapped a used bottom end in to my 2006 LSJ. Started it up and it's running rough. Idle is bouncing from ~800rpm to ~2000rpm. Some backfiring as well. It's throwing a p0017 code which is cam/crank correlation. When I timed it I made sure it was lined up, and cranked it over by hand until the marks lined back up again, I'm almost positive it's still in time. I had the cam sensor off, is there a chance that I put the cam sensor in wrong? How do I know the sensor is lined up properly?
Old Apr 10, 2011 | 01:30 PM
G11's Avatar
G11
get cylinder 4 in TDC and then put the cam positioning sensor out and look on the outside edge of it there is a little line/bump on it. you have to line up the two lines up to reset it
Old Apr 10, 2011 | 02:22 PM
Alright thanks. Would the p0017 code cause the car to run like crap?
Old Apr 10, 2011 | 02:32 PM
madmark's Avatar
yes, cam correlation will make it miss, it may be off one tooth on either side or the sensor may be bad but im guessing timing
Old Apr 10, 2011 | 08:21 PM
Well got it straightened out. Took it for a drive and now it's throwing a ton of codes and going into reduced engine power.
System too lean
Tb-maf correlation
p1182
and another one that i can't remember.. WTF IS GOING ON!?
Old Apr 10, 2011 | 08:25 PM
I'm off warranty and not paying through the ass until I absolutely have no choice.
Old Apr 10, 2011 | 08:26 PM
srt-10's Avatar
you sure everything is hooked up correctly? all the injectors spraying? plugs firing?
iboost's Avatar
i have a p0017 code. I think I'm just going to take it to the dealership
Old Apr 10, 2011 | 08:28 PM
Yep, can feel the injectors clicking and it's got four brand new plugs in it.
Old Apr 10, 2011 | 09:38 PM
Bump for answers
Old Apr 10, 2011 | 10:47 PM
zfissette's Avatar
Dont fight the obvious answer, if it says your timing is off, find out. I know thats probably not the answer you wanted to hear, but its rare for a pcm to be wrong about that.
Old Apr 10, 2011 | 10:54 PM
I already dug into that. It was actually my CPS out of time. It's no longer throwing the cam/crank correlation code.
Old Apr 10, 2011 | 10:59 PM
DoMiStIc_RuSh_06's Avatar
Sounds like you have a vacuum leak somewhere. That would explain the maf and system lean code.
Old Apr 10, 2011 | 11:06 PM
I was kinda wondering that too. I towed it up to Pat's tonight. He's gonna smoke it for me.
zfissette's Avatar
something that might be corrected by a good tune? if everything is mechanically sound, no damaged wiring or anything then it may just be a matter of dialing it in.
Old Apr 10, 2011 | 11:07 PM
Ok cool....let me know what you find out.
Old Apr 10, 2011 | 11:08 PM
It's running 42's and a 3.0" pulley on a GM Stage II tune, I don't think it's that.
Old Apr 10, 2011 | 11:10 PM
Nah, a tune won't correct this. There's an issue somewheres. In never did this when I owned it and it never did this before the motor went. There are just some things that's tunes won't fix and this is one of them lol.
Nick, never thought but could have a damaged wire going to the maf.
Old Apr 10, 2011 | 11:13 PM
It's possible, but I was extremely careful when I installed my intake to make sure the MAF wires weren't pinched. I'll double check tomorrow.
Old Apr 12, 2011 | 08:10 PM
So we drove it in the garage to do a smoke test and it threw another p0017 So I pulled the valve cover and timing case off and rolled the engine over for what seemed like an eternity and was surprised to find the engine still in time, WTF? I just drove home and pulled the crank sensor out of my old block and I'm just about to go change crank sensors.
So cam sensor is in time, engine is in time, it's about to have a known working crank sensor installed... If it throws the code again what do I do? Case relearn?
Old Apr 12, 2011 | 09:21 PM
Hmmmm.....could try the crank relearn but you shouldn't need to. How does it drive? Lagging power? Any misses when u go to step into it?
Old Apr 12, 2011 | 09:37 PM
Cranks forever before it starts and I've gotta give it throttle to get it running. Every once in awhile it'll back fire when I try to start it the first time. Hitches and bucks going down the road, goes in to limp mode every time it sees any boost.
Old Apr 12, 2011 | 10:02 PM
Hope you get this figured out man car troubles suck.
Old Apr 13, 2011 | 03:59 PM
Fixed a vacuum leak and swapped crank sensors. Everything seems to be good now
Old Apr 13, 2011 | 04:06 PM
umrdyldo's Avatar
Nice, glad it worked out. That **** would eat me alive trying to figure it out.
