just installed heat exchanger
finally installed heat exchanger!! just need to know if there is some type of bleeding procedure after everything is all set. i didnt have to add much dexcool yet. basically i wanna know what i need to do once everything is installed if anything
assuming is this the cx heat exchanger? and if it is did you take the bumper off?
damn are you still on the stock pulley for the 13.2 thats impressive man
Last edited by Jimmys2007CobaltSS/C; Oct 12, 2008 at 12:17 PM. Reason: Automerged Doublepost
Well...according to me the factory surge tank should allow the system to bleed itself (unconfirmed however) but to be safe bleed it at the h/e or leave the cap off your surge tank and let it run for 10 minutes and that should do it.
i'm using a cx heat exchanger that i ordered from ottperformance.com...it was an easy install. kept the stock one in and did it all with the bumper on and everything. i'll post some pics later on. looks pretty damn good.
n20saturn
Sep 30, 2015 12:26 AM
