just installed K&N typhoon
I just installed the intake on an ss/sc that has about 350 miles on it there is no cel on but the idle is jumping a little at idle I figure the pcm is doing its thing with recalibrating for the air differance anyone have any input?
Originally Posted by Mercury
Did you reset your battery? (Pulling the negative terminal off for about 5 minutes)
No but after about 70 miles with cai on now I have CEL and I scanned it turned up p0171 lean fuel on bank 1. I have done a search and found out this is common...I called k&n tech he said Unhook battery also so I did and it came back on after 20 or so miles. this car is going to be a pain in the **** to mod I can see this Now. Oh well I will just keep shutting the light off till a fix comes cause I love the power increase. And the motor is not running lean just real strict values on the pcm. When I had my srt-4 if you did not have stage 1 the CEL would come on if you put on a down pipe but stage 1 would not read that 02 sensor.. with that said maybe the GM stages will be more mod friendly. L8R
Delta coupe
Sep 30, 2015 08:11 AM
