just installed my meth kit need some help
Old Oct 16, 2009 | 05:23 PM
Bl4des's Avatar
I just installed my meth kit and i want to know when i should have the meth start to come on and when it should be fully spaying. I have the devils own progressive kit. I am using 60% meth and 40% water and i am using the 7gph nozzle. Now is the 7gph to big should i use the 3gph.
I am running a 2.8, 60s, zzp header and downpipe, magnaflow catback all 2.5 in, raw 3in intake, zzp heat exchange and gm dual pass, and tune will trifecta and will be getting retuned for the meth soon
Old Oct 16, 2009 | 05:34 PM
johnladow07's Avatar
You should start spraying it at 10psi and I would stick with the 3gph. When I ran a 5gph and ran it at less than 7psi it bogged down the car... Im spraying at 10psi with a 3gph currently
Old Oct 16, 2009 | 06:07 PM
Bl4des's Avatar
when should i have it spay full do you have a progressive kit like i do
Old Oct 16, 2009 | 06:19 PM
Snakes709's Avatar
i ran 5gph nozzle...start at 8psi, on full at 14psi....i also had 2.8" pulley and 60lb injectors.
Old Oct 16, 2009 | 06:20 PM
Bl4des's Avatar
well i only have a 3gph and a 7gph so i should run the 3gph for now or what
Old Oct 16, 2009 | 06:27 PM
Snakes709's Avatar
yes, run 3 gph....7 should only be used when running high boost and when you need lots of cooling. I ran 7gph nozzle when i had my tvs, other then that, i used 5gph. When i hook my meth up to my 370z im running 2x 3gph nozzles
Old Oct 16, 2009 | 08:46 PM
Bl4des's Avatar
ok i have the 3gph in so what do other people think should i get a 5gph or what
Old Oct 16, 2009 | 08:59 PM
drew1991sf's Avatar
wat size gph nozzle comes with the base kit?
Old Oct 16, 2009 | 09:02 PM
Bl4des's Avatar
i bought the best kit from ott that they had and it came with a 3gph and a 7gph
Old Oct 16, 2009 | 09:42 PM
stew_pidaso59's Avatar
my mods are very similiar to yours and i run the 3gph nozzle and i have it starting at 8psi using a 50 50 mix.
Old Oct 17, 2009 | 10:05 PM
Bl4des's Avatar
i am going to run the 3gph for now and on monday i will be retuning for the meth
Old Oct 17, 2009 | 10:25 PM
ColeJJones's Avatar
Bannned
dude, 5 is way to big seriously. 3 is perfect in all senses. im guessing you tune? spray from 5%-12%full. tune from that, pull some timing
Old Oct 18, 2009 | 01:03 AM
Bl4des's Avatar
i am going to use the 3gph for now but i dont tune i go through trifecta and i own the cable so retunes are free
Old Oct 19, 2009 | 02:20 PM
Bl4des's Avatar
so to start out at what psi should i start spaying meth and when should it be full i am only boosting 16.2 with the 2.8
i need some advice now i am trying to tune for the meth with vince
Old Oct 19, 2009 | 02:30 PM
Snakes709's Avatar
not much advice can be given. meth is going to make your afr richer so just add more air to when it comes on. Just rememeber. If you start at 8psi and full at 14psi (just example)....you have to keep it that way after you tune for it. You cant just go 3psi and full 10psi spraying if its tuned for 8/14 because the afr gets fucked up. Also make sure vince also tunes partial throttle. That was a issue i had. WOT the car ran great but during normal driving and lets say 50% throttle...it was fucked.
Old Oct 19, 2009 | 03:48 PM
Bl4des's Avatar
ok i will log just driving around normal so he can make sure it is right but i cant decide when i should start to spay and when to be full so i can tune for it i already went out and logged 2 runs i am waiting for my first new meth tune
right now i had it set to start to spay at 7 and full by like 11 with a 3gph nozzle
Old Oct 19, 2009 | 03:52 PM
DeepBlack SS's Avatar
ask vince for a recommendation?
Old Oct 19, 2009 | 03:56 PM
Snakes709's Avatar
it doesnt really matter what you set it to with a supercharger. It takes like what...1-2 secs to reach full boost.
Old Oct 19, 2009 | 04:05 PM
Bl4des's Avatar
i did ask him he is working on other peoples tunes he hasnt gotten back to me yet
so how i have it is good
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
justinchinn
Oct 2, 2015 12:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
