KN filter install help
Old Sep 29, 2006 | 04:31 PM
FLCobalt's Avatar
i reviewed the How to's and mine doesnt have any clamps with it, is it suppose to.
I saw one a while back that i cant find where they has to cut the plastic? what is this for and if so whats holding up the filter?
Old Sep 29, 2006 | 04:37 PM
ReMz's Avatar
are you talking about the filter or the entire CAI? the filter should just be "drop in"
cutting the plastic is the airbox mod.... emulating what you get with an aftermarket CAI
Old Sep 29, 2006 | 04:42 PM
D4u2s0t's Avatar
if you have the drop in, it should be a direct repacement... take the old one out, put the new one in, good to go
Old Sep 29, 2006 | 04:46 PM
FLCobalt's Avatar
It is but as far as the plastic piece on the bottom can i leave that off? or will the Filter fall out? some people say yes some say no.
FLCobalt's Avatar
this si the thread im reading on the how to
https://www.cobaltss.net/forums/show...ghlight=Airbox
D4u2s0t's Avatar
if you leave the piece off, you have to secure the filter
Old Sep 29, 2006 | 04:54 PM
Tomtwtwtw's Avatar
Exactly - so in that case what some people have done is get the screw-type clamp, and drill a hole through their intake tube to tighten it. That's if you're doing the airbox mod. If you close it back up, the filter will be perfectly secure, as it's a direct replacement for the stocker.
Old Sep 29, 2006 | 04:56 PM
FLCobalt's Avatar
what size clamp and they can be pruchased at autozone right?
Old Sep 29, 2006 | 04:58 PM
FLCobalt's Avatar
and where do u put the clamp because the lip is on the inside not the outside
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
grampss
Sep 27, 2015 08:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
