knocking and popping? axel?
I've noticed in the past week or so when driving if I turn the wheel back and forth as if I were doing a slalom I can hear a slight popping knocking type sound. Do you think it's an axel?? If not what could it be?
Do you have any type of vibration or anything while driving? how long has urs been like this? i think i noticed it like last thursday and i don't really feel anything different. just hear the sound.
Steering motor or column play. Have you had the PS motor replaced under the recall?
Or is it a repeated popping while turning? Your description makes me think it's only when going from left to right.
Last edited by ItalianJoe1; Nov 16, 2010 at 08:11 PM. Reason: Automerged Doublepost
if i turn the wheel back and forth as if i were going left right left right left right left right through a slalom of cones i hear it. No I haven't got the PS recall taken care of yet.
I have the same problem as well as a constant pull to the left. I've had it aligned, etc, but it still pulls which leads me to believe its related to whatever is popping. I'll let you know if I get it figured out. It also pops when I start in reverse, like something in front end is loose or something
I haven't done the recall either.
mine did it before the recall. i thought it was the ps motor but it wasnt it still pops. a local cobalt owner said he took it to the chevy place and they fixed it. but i will ask him what it was making the noise.
My car was put on the lift tonight, also can get it over bumps now and again.
Mine is when you slalom and lift pressure off the left front, aka the return steer to the right.
It's a popping as if something's loose. One of my tech's drove it and hasn't gave me any solid ideas, strut mount is hopeful as I already have an upgraded MOOG endlink on that side.
all this sounds just like what i am experiencing. I have some pull to the left. a noticeable pull, but i kinda thought it was just cause my front left tire has a slow leak.
I get the same noise when I turn back and forth also. It happens rarely when I go over bumps, but I think it has to be the right type of bump or bulge in the road to get it to pop. After it does it like 2-3 consecutive times it usually doesnt do it anymore. Its done it since I got the car and I have no clue. I thought maybe front LCA bushings or ball joint but I dont think its either. Would like to see what else people think. However my car doesnt seem to have the pull at all that has been mentioned.
edit: I have a 2.2 also. just notice its in LSJ tech.
Swaybar endlink was my thought too, a Moog unit and $50 later it's not
CAB's checked out, and I've always pulled the struts and springs apart to go Eibach's to stock and the noise still existed. Might swap upper mounts and test that.
Mine comes when I take weight off of that side, aka on left side, comes when I slalom the wheel to the right.
.CAB's checked out, and I've always pulled the struts and springs apart to go Eibach's to stock and the noise still existed. Might swap upper mounts and test that.
I wanna try and get coilovers next summer so if it lasts that long maybe that will fix it or the problem will be found then. Oh well. It's winter now so no more boost anyways lol.
my popping actually i believe went away, but i still have some cruncy type sound on any rough surface for instance speed bumps or dips in the pavement. When i got my new tires about a month ago they believed it could possibly be a bushing.
