knocking and popping? axel?
Old Jan 5, 2011 | 10:15 PM
exiged's Avatar
Maybe your springs aren't seated correctly?
Old Jan 5, 2011 | 10:24 PM
N1ckateen's Avatar
idk why they wouldn't be, they're stock. If thats the case it's not really a big deal cause I'm goin sportlines most likely once it warms up.
Old Jan 5, 2011 | 10:25 PM
Chevycobaltss3's Avatar
ok weve been cold correct, so in cold weather everything gets harder basically to turn, rotatem flip flop pee on ect, so think very hard and dont tell anyone my secret its called the cold lol sorry i love being a smart ass, if it does it in the heat i could see your coloum or even the ujoint coupler on the steering arm being bad or just cold lol........
Old Jan 5, 2011 | 10:35 PM
bobbyhill31286's Avatar
Originally Posted by gpro
Has anyone learned anything new about this problem? I have the same exact thing and it drives me insane. I have the pull to the left also, and thats the worst part.
the pop could be struts, mounts, bushings, intermediate steering shaft ( Chevy has had alot of issues with steering shafts on anything from cobalt's, monte's, impala's, malibu's, and full size trucks including suburban's. You can hear/feel a pop or clunk as you turn the wheel and when going over bumps. I have drove cars and replaced enough of these damn things lol )
The pulling could be from a bad suspension part, could need alignment, low tire pressure or a bad tire...could be radial pull, or some kind of issue with shifted belts in the tire
Old Jan 5, 2011 | 10:54 PM
mmcgee123's Avatar
Intermediate shaft
Old Jan 6, 2011 | 09:03 AM
05Blackss.sc's Avatar
popping when turning is cv axle i thought. mine pops pretty much all the time. im ignoring it untill i got lke 2k to completely replace the front and rear suspension lol. i cant locate the problem so imma just replace everything. if the car isnt pulling(mine isnt) then its not entirely a big deal. like someone said the cold probably doesnt help. but maybe try takin the boots off and greasin up. or just check to see if they are ripped
Old Jan 6, 2011 | 09:12 AM
Stone629's Avatar
This makes the most sense to me. I have had the same popping since early this summer and have been over everything except the steering shafts.
Bobbyhill sounds like he has experience fixing this issue.... it'll be the next thing I check into.
Old Jan 6, 2011 | 09:38 AM
yeayh wen i took my car in under warrenty they replaced steering colum and struts. my suspension is worse then b4. my brother(mechanic) said they probably cut corners and didnt change out the bushings. my suspension creeks cracks pops everything in the world. its terrible.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Oct 21, 2015 11:57 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Tupp
Sep 30, 2015 08:18 PM
SlowSaturn
Sep 28, 2015 11:03 AM
