konis installed ride still bumpy!! WHY???
Old May 30, 2007 | 07:53 PM
vextc05's Avatar
i got the B&G springs. And b4 i installed the konis, the ride was very stiff and bouncy, now after the konis were installed the rides still bouncy but not as stiff!!! Why does the car still ride like ****!!!!
Old May 30, 2007 | 07:58 PM
alleycat58's Avatar
What did you want the Konis to do? They're basically just sleeves for the suspension. Sounds like the problem is with the springs. Have you talked to anyone else that has them???? Have you tried adjusting the Konis?
Old May 30, 2007 | 10:23 PM
Red07Coupe's Avatar
Post
this should be in the suspension forum..... you would probably get a better and quicker response.
Old May 30, 2007 | 10:43 PM
Sicklyscott's Avatar
sounds like a spring issue but how stiff did you set the Konis to?
Old May 31, 2007 | 01:34 AM
vextc05's Avatar
to be honest i dunno, my buddy installed them for me. Ill ask him in the morning. What should it be set to?
Old May 31, 2007 | 01:42 AM
senior_brown's Avatar
i set mine to 25% all around, and i cant be happier with how they work, but im dropped on sportlines
Old May 31, 2007 | 01:56 AM
vextc05's Avatar
prior to the konis was ur ride pretty bad?
Old May 31, 2007 | 11:20 AM
silverSS's Avatar
could be those springs!
Old May 31, 2007 | 11:29 AM
Rangerondubz's Avatar
I need new struts, I dk if I should go w/ the Konis or just stock replacement ones
Old May 31, 2007 | 12:58 PM
Eddie's Avatar
sounds like something isnt installed right, double check the install, also check bump stops make sure u removed or cut those according to B+G specs.
Fearedbynone
Apr 14, 2016 03:25 AM
riceburner
Oct 2, 2015 05:47 PM
justinchinn
Oct 2, 2015 12:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Cobalt_Daddy
Sep 27, 2015 06:59 PM
