KPA vs PSI gauge
Old Sep 18, 2007 | 10:44 AM
icemaid's Avatar
KPA vs PSI gauge
Never seen a kpa gauge before my balt.
Which is the better type gauge: the KPA or PSI??? Why do Canadians have KPA & Americans have the PSI?
Old Sep 18, 2007 | 10:45 AM
SSdan's Avatar
Same damn thing. Just one shows in KPA and one shows PSI.
Personally, PSI is alot easier for me to understand.
Old Sep 18, 2007 | 11:41 AM
RedlineBrian's Avatar
Metric System.
Old Sep 18, 2007 | 01:55 PM
Sergio's Avatar
KPA is sort of cool because it's the same unit for vacuum and boost. However when someone asks "How much boost you running!?" saying "110!" would get you wierd looks.
Old Sep 18, 2007 | 01:57 PM
an0malous's Avatar
mine came with kpa, in canada.
but i swapped it out with psi.
MUCH easier at a glance.
and even though this country is metric, there are still some things that have always remained imperial.
Reading air pressures is one of them. (for alot of people anyway)
Old Sep 18, 2007 | 02:00 PM
RuSSo-29's Avatar
thats weird. I didn't know that. Very interesting. Would have figured tire press gauges up there would be metric?
Old Sep 18, 2007 | 10:48 PM
feavs's Avatar
Did you swap out the entire gauge, or did you just swap the faceplate? How long did that take to do? Where did you find a psi gauge?
I'm in the same boat, I can't stand the kpa.
Old Sep 18, 2007 | 11:26 PM
sunfirejoe's Avatar
KPA is not a unit of vacuum,
vacuum in standard conditions is
inches per water column
heres a quick conversion for people
there are 407 "H20(WC) for 14.696 PSI which is equal to 101.325 kpa which is also equal to 760 mmHG(mercury), which is also equal to 29.92 "HG(mercury)
typical canadians will refer to pressure as PSI, but im my line of work, i need to be able to figure out how many newtons of force there is on a diaphragm for actuators,
i prefer my self working in either KPA or BAR, PSI there is nothing wrong with it, as everyone works with it in your car, but when u hear someone say they 40 inches of vaccum, they are talking about water column not KPA. there is a huge difference,
just my stint for the evening
Old Sep 19, 2007 | 05:46 PM
an0malous's Avatar
the whole gauge.
its a 10 minute job.
I bought it off members in the states who replaced theirs with mechanical gauges or whatever.
Old Sep 19, 2007 | 06:07 PM
feavs's Avatar
the whole gauge.
ahh ok cool. Thanks for the help.
feavs
www.feavs.com
Old Sep 19, 2007 | 06:10 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
kilopascal = 1000 pascals = 1000 Joules/cubic meter
Its a force per unit area just like psi is.
Old Sep 19, 2007 | 06:21 PM
OneAMCoffee's Avatar
Vacuum can and is measured in kPa, it is simply labeled as below atmospheric pressure. It, vacuum, is most often measured in mmHG (millimeters of mercury) or inHG (inches of mercury). You can use water but mercury is preferred because of its high density and low vapor level. You could be cool and measure it in torr and pascal (Pa) too, just no one will know what you are saying unless they are a science buff, or a scientist, or an engineer. My tidbit for the day.
Regards,
Ryan
Old Sep 19, 2007 | 07:47 PM
tkaugh29's Avatar
wow you think simple question = simple response.. i guess not, i love the PSI guage, if your gonna buy an PSi guage get the Autometer 'cobalt' one. its wicked.
Old Sep 19, 2007 | 07:59 PM
Yeah it really is simple and PSI is a lot easier for most unless you need another unit of measure for personal or specific reasons.
Regards,
Ryan
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
no_ss
Oct 18, 2015 11:58 PM
Sep 27, 2015 08:53 PM
