Laminova core removal
Old Nov 11, 2011 | 08:13 PM
insylem's Avatar
Question Laminova core removal
How in the name of Zues' butthole do you get the laminova cores out of the intake manifold. Ive already managed to bend on slightly (hoping it wont leak)
Old Nov 11, 2011 | 08:16 PM
TStone's Avatar
I kinda just got a good grip on it and pulled it out.. kinda used my nails to my advantage... I seen a how to for the dual pass and it was saying like make sure to not **** anything up and I had to pull a little harder then I wanted but I didn't hurt anything
Old Nov 11, 2011 | 08:20 PM
insylem's Avatar
My fingers keep slipping off, those things are in there tight. Ya I saw that how to also and i Hope I dont much anything up, otherwise im gona be without a car for a while and have to buy an entire intake manifold from the stealership just to replace a messed up core.
Old Nov 11, 2011 | 08:29 PM
troyss's Avatar
Use plyers
Put black electical tape around em first and be carefull doing so
Old Nov 11, 2011 | 08:34 PM
TStone's Avatar
Go get some fake finger nails from the Dollar Store.....
Old Nov 11, 2011 | 09:02 PM
insylem's Avatar
I used pliers, carefully, i bent them just a small amount. I used a rag so that the pliers woudln't gouge into the laminova core. Swaped the bottom two directionally. Put the lil copper things back and poped on my endplate. I put the manifold in the bathtub, the inlet hose hung over the toilet and the outlet hose connected to the sink, I ran water through it (not realiseing its backwards) and I could find no leaks. So I ran water through correct way in the tub and coudlnt find any leaks either.
Question: If there is no check valve in the laminova core, why does the direction matter?
Old Nov 11, 2011 | 09:05 PM
Powell Race Parts's Avatar
using pliers is fail. find a wood dowel or a round handle that will be a snug fit in the core,( I use the plastic covered handle of a T allen wrench I have) insert in the center of the laminova core, twist and draw out.
they are soft. they do get damaged easily. I have a box full for such issues that come to the shop. be careful.
experience with this helps a lot.
good luck.
Old Nov 11, 2011 | 09:23 PM
insylem's Avatar
I know useing pliers is fail but I didnt have anything ealse And I didnt have a way to drive my car without an intake manifold. So I wraped arround with a rag and hoped for the best. It did dent them slightly but they didnt seem to leak when I leak tested it in the bathtub.
Old Nov 11, 2011 | 09:25 PM
^^ you did your best and hopefully it works. it should the seals are pretty good, and there is not a lot of pressure in the system less than 5 psi max.
Old Nov 13, 2011 | 03:53 PM
insylem's Avatar
5 psi max with the water, but then the intake side gets say a 10 psi vacume, makeing the water to intake psid arround 15,
then under full boost (18 psi ) it pressures the other way , to 13 psid
Old Nov 13, 2011 | 07:24 PM
Leafydialupking's Avatar
I got mine out how powell racing suggested but I was able to use only my finger on all but one. On that one I had to bust out the channel locks, and just gave it a gentle 1/4 turn and then it popped out by hand.
Anyone else comes across this thread and is trying to get them out, clean the damn things, use a whole can of throttle body cleaner on them when they are out of the intake. Mine were willed with oil. They also did a good job of collecting a bunch of stuff that I would have found undesirable to get into my engine which somehow made it into my intake manifold.
Old Aug 7, 2012 | 08:31 PM
Dave1515's Avatar
So the best way to clean them is to use throttle body cleaner?
Old Aug 7, 2012 | 08:47 PM
i use brake clean but dont get it on the seals. The blow it off with compressed air, be careful not to bend the fins. And no , the pressure inside the laminova cooling system is less than 5 psi, boost has nothing to do with the coolant (heat extraction )side of the laminova cores/system.
the order of assembly is thin ring, thick ring, o ring last. Place them on the core, then pop them in; line up the big slots in the fins with the big slots in the IM. Dont leave the o rings inside the IM and try to seat the cores, it wont go well for you if you do it that way.
the purpose of the blank end for the inlet 0 oo 0 is the slow the freshly cooled (from the heat exchanger radiator) coolant down and force it in the sides ( the little square holes) to enable transfer of heat via the fins to the coolant. The the exit cores have a large opening so that the heated coolant gets moved out asap.
Old Aug 7, 2012 | 09:16 PM
ei3dag3's Avatar
so what i did was use a worm clamp. a baby sized one
you tighten that carefully on the end then pull them out.
good luck!
Old Aug 7, 2012 | 09:23 PM
^^^ good one! I have done that too.
Old Aug 9, 2012 | 07:17 AM
Staged07SS's Avatar
Administrator
Administrator
See my how to for installing a dual pass endplate....
I have pictures showing what to do.
Old Aug 9, 2012 | 09:14 AM
insylem's Avatar
Thanks, but I got it installed months ago
Old Aug 9, 2012 | 09:33 AM
klotzy_550's Avatar
good luck!
^This. I used this method back when I swapped my cores. Personally I believe this is one of the better approaches because you dont localize all of the clamping forces all in on little area, which results in clean core removal. Just take your time with them and dont go hog wild with the tightening of the hose clamps, just enough pressure to maintain contact.
Old Aug 9, 2012 | 09:42 AM
Staged07SS's Avatar
Administrator
Administrator
Hahaha, wow....
I didn't even realize someone brought this back from the dead.
Sorry about that.
Glad you figured it out.
For anyone else wondering how to remove the Laminova Cores.... See my thread.
https://www.cobaltss.net/forums/how-...rnator-274630/
Old Aug 9, 2012 | 10:00 AM
CleverOne's Avatar
good luck!
This...
Old Aug 26, 2012 | 04:42 AM
needspeedss's Avatar
Where can I buy the cores at mine are bad I think
Old Aug 27, 2012 | 07:29 AM
Staged07SS's Avatar
Administrator
Administrator
Crate Engine Depot, or even ZZP sells them....
DarrenGC
Dec 24, 2021 01:55 PM
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
