Lash adjuster problems? *tick tick tick tick*
Long story short - I have been experiencing a "tick tick tick tick" when the car is cold, regardless of outside temperature. It has been an ongoing problem but I have ignored it for a while, however, it has recently begun to bug me because I know it isn't normal.
It will happen right when I start the car and whilst the car is still idling cold, my exhaust note sounds like I have a cam, or a constant misfire, sort of like a Subaru motor. When it is warmed up, great, no noise that I can hear, exhaust note is fine, even when accelerating, everything is great. No power loss, nor MPG loss.
I know lash adjusters go out when you rev high and the car has 85,000 miles on the dot, so I think this may be the problem.
Timing chain tensioner is the new revised version
SC coupler is the ZZP one
Plugs are 1-step colder NGK Iridium
Basically this is not the common timing chain noise which has a different sound.. And likewise comes from the passenger side where the chain is located. This is coming from the driver's side - No doubt about it.
How do I check if any lash adjusters are fubar'd? I'll be going into the garage to tinker with it and if I find some which are broken I'll post back and take it from there. I just need to know how to diagnose a bad one, or one on it's way out.
Thanks
Thanks
The sound in the video is 100% dead on with my car. Well, I guess I can rule out lash adjusters.
I found out what the problem is!!!!!! You must re-torque the exhaust manifold nuts! That is all. It is an exhaust leak. I guess GM under torqued the manifold nuts on our cars. I re-torqued them to about 130in/lbs, and no more ticking!!!! Took care of it and increased the power!!! Much nicer now.
I think I'm about to cry..
How in the hell did you get a torque wrench in there lol??
Hey dude, I remember us talking about timing stuff a while back. Well turns out all my stuff was ok! It was my rod bearings!
.... yeah.... mine was a healthy "tick" though.
Not implying that's what yours is. Just thought I would share. Words of advice: try all accessories and suggestions as above before tearing apart the front end of your motor, replacing all timing components, and taking the whole valvetrain apart.
Good luck!
Good luck!
I tightened all of the exhaust manifold bolts in sequence minus the 2 on the driver's side that are a complete bitch to get to from above and my jack is at my buddy's house so I'll get those later today.
Oddly enough I didn't hear it when I started the car this morning.. Maybe that's what it was because some of them weren't as tight as I would have liked..
Sub'd for later, my car has been making this noice for as long as I can remember on cold starts, I just began to think it was normal. That video is bang on how my car starts, Icould swear someone recorded my car and put in on youtube lol
Still haven't tightened the last 2 manifold bolts on the driver's side, I need a swivel and I can't seem to find mine..... To be continued tomorrow......
dude, there is no way this is my problem, but this is exactly my situation, sounds exactly like a bad lifter, but i recently switched exhaust manifolds, ill have to go bad and retorque see if this fixes it. xxxsh4dowxxx please let us know if this fixes the problem
my car has had a small noise like that since she had four miles on the odometer. Could be an exhaust leak, but gm motors are known for having a noise like that on cold startup. Its when your car is at operating temp that i would worry about it. hydraulic lifters sometimes need to prime a bit before they quiet down
