Lash adjuster problems? *tick tick tick tick*
when i did my header/ dp / catback install it was good for about a week
then it would sound like a bi -propeller plane haha
i just needed to re torque the header bolts
Currently i have some ticking at cold start ups as said on previous posts
i have a new timing chain tensioner that ill install soon tho
This is mine ... Cobalt chain - YouTube
I've been assuming its the chain / tensioner . The noise has gotten worse over a fairly long period of time , but car always pulls hard , drives great , no leaks , clean oil . Any idea what everyone thinks it may be if you don't believe it's my chain / tensioner ?
Yea it seems a bit impossible with the 1/2" torque wrench... but a swivel head is not going to torque it up to spec correct?
3/8 torque is probably your best bet, feel the other ones with the torque wrench at the same length along it as your ratchet and go by feel on the other one if you need.
Joel
Very funny
D
About first vid - it's 100% camshaft position house ... there have a biggest gap ...
But don't try to get off it ... because you must place it back in TDC position (see in manual) ... it's f**king terrible because camshaft housing always lost needed marker ...
You can test it - just lift up right front wheel ... and you'll see - noise will gone ...
update to my vehilce, dropped off to the dealer last night , they are working on it now. So far indications are chain tensioner as we all expected and will be warranty work even with my mods.... so far ( crosss fingers )
new update, dealer now thinks its the belt tensioner that has gone bad and stated that the belt has been worn badly because of it. thats not covered by powertrain warranty , but might be by extended , dealer is checking that out... altho I dont tink they realized yet, teh belt is a stg 2 belt....
Very funny
D
You can try to change GAP there ... but you can brake sensor teeth there or lost it from sensor reading-position
It's #12600008 ... 734 on first picture ... and 20 on second
