limited-slip differential
Old Nov 3, 2007 | 03:56 PM
bamaboy22's Avatar
can this be bought somewhere. or was it just offered with the g85? i tryed to look for it but only found stuff on it in ss/tc
Old Nov 3, 2007 | 03:57 PM
shabodah's Avatar
Quaife has it on their site. It's only $995 for the part and about $650 for labor at most places.
Old Nov 3, 2007 | 04:20 PM
bamaboy22's Avatar
thanks i can do the work my self. i work at the dealership
Quaife who is that i cant find there page...
Old Nov 3, 2007 | 04:25 PM
shabodah's Avatar
I work at a dealership myself. I've met about 3 people who can work on a F35 compentently.
Old Nov 3, 2007 | 04:30 PM
bamaboy22's Avatar
im not saying im going to do the work. but i got a guy that is master ase mec. so i can get it done. can i get a link
Old Nov 3, 2007 | 04:39 PM
SS Gordon's Avatar
I found this in my favorites but who ever said $950 so off by this link.
http://www.nolimitmotorsport.com/prod/57-309-180
I'll see if I can find it cheaper
Just type Quaife ATB Differential: 57.309.180 Into Google & abunch pop up
Here's another for alot cheaper!
http://www.manufacturersdepot.com/SP...1180622061.jsp
Old Nov 3, 2007 | 04:47 PM
aj_92rs's Avatar
Why not just buy a used trans with the LSD?
bamaboy22's Avatar
thanks. so this is going to get me less tire spin?
Old Nov 3, 2007 | 05:42 PM
alleycat58's Avatar
Not necessarily. Minor reduction, mostly though you'll just spin two wheels instead of one.
Old Nov 3, 2007 | 06:23 PM
SS Gordon's Avatar
No I don't have LSD & I still spin 2 tires, it just helps in the corners & pulling out into trafic cuz if your turning the LSD transfers the powerto the traction wheel hence limited slip dif
Old Nov 3, 2007 | 07:26 PM
aj_92rs's Avatar
Limited slip means it slips limitedly. As in, when you're making a turn the outside wheel turns faster than the inside wheel. The differential slips just enough to keep the wheels from trying to turn at the same speed.
The amount of torque distributed between the wheels is limited (hence the term). If 100% of force were able to be distributed to both wheels then this would be a locked unit with no differential effect.
I put a Powertrax locking differential in my '92 Camaro. It would lock and unlock through turns to act as an open differential, but once torque was applied it locked the teeth and acted as a straight axle.
It was great for straight line acceleration. AAMOF, it shaved .3 seconds off my 60 foot time after installing it. But it sucked when I accelerated through turns or curves. I could feel the rear end trying to push the car straight. And it was hell in the snow. Both wheels spun all the time when I was trying to accelerate.
Limited slip helps prevent that.
Old Nov 3, 2007 | 07:39 PM
TurboTechRacing's Avatar
We carry the LSD at www.TurboTechRacing.com
Qualife brand
SSnRXP
Dec 4, 2015 11:02 PM
ashalle2
Sep 16, 2015 10:36 PM
JonyyB
Mar 27, 2006 12:56 PM
zinner
Feb 4, 2005 08:10 PM
JonyyB
Jan 6, 2005 05:52 PM
