limp mode
Old Jun 1, 2006 | 01:49 PM
hondaeater's Avatar
limp mode
I am writing this to u from this side of the road. my car has gone into limp road and won't restart.. any idea how to fix?i think it happened bcuz I redlined and missed gear. ty vm in advance
Old Jun 1, 2006 | 01:50 PM
Acidangel_5.0's Avatar
just give it a few minutes then start it back up
this has happened to me one time.. i just had to sit for about 3 - 5 minutes and she started back up fine
Old Jun 1, 2006 | 01:51 PM
John's Avatar
try to let it cool down see what happens
does it turn over at all or no
3fo893013L's Avatar
let it sit for a few minutes and start and shut it off several times to reset the PCM.
Tomtwtwtw's Avatar
Hrm...I've done that a few times, and other than the embarassment of revving your engine and not moving fast in traffic, your car should be fine. Have you called roadside yet?
Old Jun 1, 2006 | 01:52 PM
sscobalt06's Avatar
My car did this, i ended up pushing it thru downtown Houston in the middle of the night about 5 blocks, got back in and it started up fine.
Old Jun 1, 2006 | 01:56 PM
hondaeater's Avatar
I've done all your suggestions and nothing. this is embarassing and no engine turn over
Old Jun 1, 2006 | 01:58 PM
1stbluSS's Avatar
if the engine is not turning over you have a problem more severe then limp mode... limp mode will allow you to limp your way back to your destination.....
you will have no boost and only 2 cylinders... your exhaust will also sound like it is farting....
on another note I was bangin my girl the other day and i stopped, she asked what happennend I said LIMP MODE !
Old Jun 1, 2006 | 01:59 PM
1stbluSS's Avatar
Also Disconnect Your Negative Battery Cable... Wait 5 Mins Then Reattach...
Then Start Er Up !
Old Jun 1, 2006 | 02:00 PM
CTCOBALTSSS's Avatar
What kind of gas is in the tank?
Old Jun 1, 2006 | 02:04 PM
hondaeater's Avatar
no ******* tools with me and 93
Old Jun 1, 2006 | 02:09 PM
DWK5150's Avatar
Option 2: Call a tow truck.
Old Jun 1, 2006 | 02:13 PM
hondaeater's Avatar
been waitin for 45 min
Old Jun 1, 2006 | 02:19 PM
Try one more thing. Put the key to the 2nd position, (One past the radio position) Give it about 5-7 seconds and then give it a try. That will build fuel pressure. Give it a whorl!
It could be an intake leak or issue. Check all connections in the engine bay
Old Jun 1, 2006 | 02:21 PM
1stbluSS's Avatar
do this.... this will definately fix it...
when the next car drives by jump in front of their vehicle.... then steal it and drive away
i see driver mod coming pretty soon
Old Jun 1, 2006 | 02:46 PM
XSNRG's Avatar
just in case try putting the key in the run position 3rd p0sition and let it sit for approximately 10 minutes. in gm cars this can be used to reset the bcm in certain cases (security light etc..) just an idea though. and some more info does the car crank and then not turn over or nothing at all.
Old Jun 1, 2006 | 03:37 PM
stonny9's Avatar
turn the key on then push the car and pop the clutch
Old Jun 1, 2006 | 03:38 PM
we call this a kick start.. but does no good if your car isnt giving power to fire
Old Jun 1, 2006 | 06:23 PM
hondaeater's Avatar
Hey guys,
I'm back. Here is/was the problem.
Apparently after Rob's looneytune, the Stage 5 S/C and whatever else I did, caused the F/I fuse to blow.
This was found after compression testing, and finding that the plugs weren't firing. We replaced the 10amp fuse with a 15, and all is well.
HOWEVER.....
When this happened, I noticed that:
1. My radio, and it's peripherals are all dead. I don't know why, but they are.
2. My factory remote does not open the doors, trunk, or the emergency alert doesnt work either.
What is getting me is that I checked all fuses, and they are kosher. Did I miss something?
Please advise,
Hnda
Old Jun 1, 2006 | 06:52 PM
Hey guys,
HOWEVER.....
Please advise,
Hnda
Wow i'm glad to see you made it. That sucks about the radio and remote. That's going to be a job for the dealer. See guys, this is what happens when you go stage 5 and Intense or any aftermarket stage kit for that matter. Nothing against Intense at all they do outstanding work. It's just there is no warranty. Now who gets stuck paying for this fix out of his pocket? Hondaeater! When it wasn't even his fault. Go GM! Either way bro I'm glad nothing crazy major happened. Later...
Old Jun 1, 2006 | 06:53 PM
Anthony's Avatar
lololol
Old Jun 1, 2006 | 07:03 PM
snowcrash's Avatar
Dude cut him some slack sheesh. All intense has to do now is include a 15amp fuse and all is good. Just because someone goes with Intense and something happens doesnt mean that GM rules. My brother has an EVO that cranks about 400whp and yeah stuff happens from time to time, but if you wanna play with the big dogs you're going to have to pay to play. We get it GM is covered and nothing else is. Can we finally move on now.
Old Jun 1, 2006 | 07:12 PM
Wow, relax. Cut who slack? As you can see I feel for the guy. This is my opinion. And that's my point about GM and aftermarket, you will end up paying to play with these aftermarket kits. Yeah the power is awsome everyone wants it. The point to my thread was exactly that and only that. My OPINION is go GM for reliability. People read these threads to see everyones different opinions on topics. It's OK!
Old Jun 1, 2006 | 07:20 PM
BooSSted's Avatar
That fuse could have blown for any reason. Probably has nothing to do with the ECU upgrade.
