A little confused
Once you go stage 2 or higher any cooling mods help reduce IAT and heat soak, which will help especially on consecutive hard runs or extended hard runs. Like I said before, if the IAT gets too high the car will reduce boost or pull timing. Even on a stage 2 or higher car you will not GAIN HP with cooling mods unless you are tuned for it, you will simply stop detonation and engine damage. But with the cooling mods you can get tuned and run more timing which will gain you HP.
If you are just installing a header you shouldn't get a CEL. If you install a downpipe with high flow cat or go catless then you will more then likely get a CEL.
wow, you might wanna tell this guy that hes doin it all wrong then
![Thumbsdown](https://www.cobaltss.net/forums/images/smilies/thumbsdown.gif)
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/different-approach-modding-your-cobalt-75313/
wow, you might wanna tell this guy that hes doin it all wrong then ![Thumbsdown](https://www.cobaltss.net/forums/images/smilies/thumbsdown.gif)
https://www.cobaltss.net/forums/showthread.php?t=75313
He is saying the same crap I just said - HE TUNED FOR THE COOLING MODS!!!!!
You didn't even quote the entire thing:
If you are going to try and make smartass comments at least read everything first.
#37
Ok,is there a way you can get rid of the cel? Cuz some cars they have antifoulers and that will get rid of the light. So when running a smaller pulley will I throw a code?
#38
Seriously, did you even read ralliartist's thread or just stick the link in here because you felt like it?!
in the begining all he did was **** with tq mangament, boost limits and raised the redline. he didn't "tune for cooling mods" and still had gains in the 1/4.
#46
#48
You can clear codes by simply disconnecting the battery. If you want to DELETE a code you must use HPTuners to delete it.
A tune and flash are basically the same thing... normally a flash is a simple write done at a dealer. A tune is when you actually get HPTuners (or other tunign software) and make adjustments. Another option done by some vendors is to swap the actual PCM.
#49
#50
Question: Does this car have a Adaptive or Learning ECU?
