A little confused
A little confused
I need help on mods. Which is better from me in all stock now. I have a 07 S/C. I wanna spend around 300-400 bucks right now nothin serious. How does the pulley system work? The stage system? Im not new to cars only supercharged one
a wot box? for a first mod?
that doesnt make alot of sense.
what do you want from your car with your mods?
usually exhaust work is the biggest all around bang for your buck mod.
good performance gains, nice sound improvements...
iight so what size exhaust would i need/get. I had 2.5 catback on my sprayed tc but, i was thinkin since the F.I i would need 3 inch? no?
and to answer your question i want power
I would go with a 2.5 or 2.75 inch exhaust
Small the pulley is the more power you will make. but dont think of it like that, if you go lower and a 2.8 then your starting to look into meth and dual plate. but meth is always good
2.8, 60s, HE, and a tune will be just fine
anything lower than a 2.7 is over spinning the supercharger and the heat it puts out in HARDCORE!!! all you gotta do is go on cobalt addiction and buy a pulley, 60s injectors/harness, stage 2 belt and ngk bkr7eix spark plugs.... and then go to the dealer ship and drop down the cash for the reflash.. around me its $94 but other places may be higher or lower
Yeah, if you get 60s you are going to have to take the car somewhere to get it tuned. Actually if you do any injector upgrade you are going to need to get the car tuned unless you get the GM stage 1 or 2 kits which come with the GM tune.
2.7 is inches. 79mm is oviously mm. 79mm = 3.11 inches. 2.7 inches = 68.5mm.
no they make pulleys all the way down to 2.5 but imo anything past a 2.8 is counterproductive because it generates so much heat that the power increase gets washed out. if you want reliability, stay with a 3" or a 2.9" pulley with 42# injectors. If you want to get a substantial amount of power more without really having too worry about any headaches, go with 60# injectors and 2.8...all with a custom tune of course
doc, got the rims today...thanks for getting them out so quick! I got them on today and they look sick! thanks man! let me know if you have anything else for sale and I'll throw you a good seller bump
Last edited by boostaddict; Jul 29, 2008 at 05:52 PM. Reason: Automerged Doublepost
awesome...glad you like them, now get them installed and take some pics.
shut up...he doesn't even have stage 2.
You can do 2.7 on 60's maybe 2.6; just depends on the hub. For 300-400 bucks I'd pretty much have to say put together you're own stage 2 (injectors, hubbed pulley, belt, tune) if you can...or get some "silly gas"; but putting nitrous in an american car is sort of blasphemous.
Last edited by theneelster; Jul 29, 2008 at 06:16 PM. Reason: Automerged Doublepost
if you change the pulley, you need a hub...unless you get a press on, which I have seen very few people use.
3.3 is stock I think
The dual pass for the intercooler allows 2 intakes for the coolant to enter the intercooler instead of the quad pass from the factory. I.E. The stock intercooler has the coolant flow in from one hose then passes through all 4 laminova cores then back out and into the HE to cool. With the dual pass you have 2 intakes into the intercooler. Each flow only goes through 2 laminovas then back out to the HE. This does two things: 1. It helps to keep the IAT lower as the coolant does not get as hot in the intercooler because it is only making 2 passes instead of 4. 2. It reduces heat soak because the coolant does not get as hot as fast.
