LNF piston rings in an LSJ?
Old Jan 20, 2014 | 08:19 PM
CradleofFilth08's Avatar
Please forgive my ignorance but...Would that work? I keep seeing all the prices for LSJ parts being astronomically higher in comparison to LNF parts. Just to save some money and possibly have a better part, would that work without having anything go wrong?
Old Jan 20, 2014 | 08:29 PM
574's Avatar
574
Call total seal, tell them what you want and they will get you hooked up. I wouldn't run anything else. And its not lsj vs lnf rings. They are both boosted cars. It depends on your cylinder bore and piston size
Old Jan 20, 2014 | 08:50 PM
I have stock LSJ pistons with a S20G turbo pushing 15lbs so I'm at least trying to get a little insurance on something...I know I should upgrade the pistons but I just can't afford to right now.
Old Jan 20, 2014 | 09:04 PM
574's Avatar
574
So you want to re ring with LNF?
Old Jan 20, 2014 | 09:30 PM
Because they are cheaper and I figure they are made for higher boost levels.
Old Jan 21, 2014 | 12:27 PM
mrbelvedere's Avatar
there is a difference in ring sets between the lsj and the lnf (lnf has a bigger oil ring then lsj) the lnf parts are made in usa that is why they are cheaper the lsj parts are made in Germany I believe hastings has a set of rings that will fit the stock lsj pistons but if your going in the engine that far your better off re sleeving and replacing the pistons with better parts
Old Jan 21, 2014 | 01:02 PM
JapEatr's Avatar
South Central *********
why re-ring stock pistons if concerned about insurance
Old Jan 21, 2014 | 01:12 PM
blueLNFftw's Avatar
There is a set of Diamonds in the marketplace right now...
Old Jan 21, 2014 | 02:32 PM
noorj's Avatar
You shouldn't be worried at all on 15 pounds from an 20g, the LSJ is a very strong motor
Old Jan 23, 2014 | 05:15 PM
I can't afford anything right now. My loan money had to unfortunately go to other things. I just need to get the car up and running I have a broken oil ring in the first cylinder so I'm trying to fix that with what I can at the moment.
Old Jan 24, 2014 | 10:35 AM
I doubt it is a broken ring more like a piston
Old Jan 24, 2014 | 04:46 PM
1st cylinder is 15 lbs low on compression and it's burning oil not too terribly bad.
Old Jan 24, 2014 | 04:57 PM
you probably have a busted or cracked ringland
Old Jan 25, 2014 | 02:50 PM
mongorat427's Avatar
Sounds like a piston and the rings are different for sure
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Trav3480
Oct 1, 2015 08:17 PM
patooyee
Oct 1, 2015 01:07 PM
