Location of spark plugs?
Originally Posted by uhcougar08
Is there anything special about these spark plug cables compared to regular spark plug cables?
This setup basicaly eliminates having to change plug wires, also a nice side effect it that most 4cyl cars have only a 2 coil setup, meaning that it actually sends power to 2 plugs at a time, of course only 1 is on it's power stroke, and in theory by some physics that I don't want to understand, only that one actually fires.
In our system however, it can be assured that only the right plug fires at the right time, also in theory every cylinder could possibly be individually tuned.(not sure about if the last bit is actually done in our pcms) And you only have to replace single coils if one dies, not the whole coil pack as in typical cars.
Another vehicle that is using this system is the 2007 Jeep Compass, I'm sure there are/will be others.
Originally Posted by ecoteched
The regulars one can have a difference in power per each spark. The coil on plugs maintian an even amount of power per each spark. Can help prefent misfires...
[QUOTE=bredick]This setup basicaly eliminates having to change plug wires, also a nice side effect it that most 4cyl cars have only a 2 coil setup, meaning that it actually sends power to 2 plugs at a time, of course only 1 is on it's power stroke, and in theory by some physics that I don't want to understand, only that one actually fires.
Both plugs fire, but the companion Cylinder is on its exhaust stroke so it is dubbed "waste spark system"
Originally Posted by BlackSS05
I would. anytime you mess with anything electrical i would remove the positive terminal of the battery.
Just FYI
