CASE Relearn
Old May 27, 2006 | 12:36 PM
BooSSted's Avatar
CASE Relearn
Does anyone know if there is any other way this procedure can be done other than at a GM Dealership? I do not want to install my Intense ECU and go in there because they are going to void my warranty when they see the mods.
Old May 27, 2006 | 04:11 PM
03gobluecobra's Avatar
I ran into the same issue. I don't know of any other way to do this than at the dealer unforuntately.
Old May 27, 2006 | 04:18 PM
black06ss's Avatar
try another performance shop. there should be atleast one around with a tech 2.
Old May 29, 2006 | 02:16 AM
CobaltSS313's Avatar
can someone with an OBD2 scanner do the case relearn?
Old May 29, 2006 | 10:23 AM
zinner's Avatar
Moderator Alumni
Haven't seen a scanner that does case relearn.
Old May 29, 2006 | 02:29 PM
SilverSS/SC's Avatar
There seems to be quite a few shops in Canada that deals with GM performance cars . Maybe one I your area would have a tech2 . Worth a look see .
....and for whatever its worth . If you ever had a engine related problem and had to take the car to the dealer , they would find out anyways . They cannot legally void your entire warranty because of the PCM . Keep that in mind too . Your basically in the same spot if you do or dont have the dealer do the case learn .....so ya may as well just have them do it . JMO .
Old May 29, 2006 | 02:32 PM
player_1's Avatar
biggest problem with the dealer is they'll hassel you every time, and they'll charge $100.00CND to do it. min. 1hr labour.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
HEATON
Oct 16, 2015 07:21 PM
agentirons
Oct 16, 2015 02:11 AM
Tupp
Sep 29, 2015 11:07 PM
