loss of power?
Old Apr 25, 2011 | 12:57 PM
blacksss's Avatar
loss of power?
over the winter i picked up zzp stg 3 kit. after installing for the first few months my boost gauge was hitting 20 psi. for some reason now it only manages at the most 17 psi. anyone have any idea of what could be wrong?
Old Apr 25, 2011 | 01:10 PM
Hockeyman's Avatar
clogged cat
Old Apr 25, 2011 | 01:30 PM
K-Train04RL's Avatar
a clogged cat would result in higher psi.
the colder air would normally produce higher psi because the air is denser in the winter. hot air is thinner, so the psi would be lower.
Are you throwing any codes? does the car feel fine still? is your loss of power actually a loss of power, or just the boost needle not pushing 20 anymore? psi does not always mean power. psi is a measurement of restriction at the intake manifold. also if u have installed anything exhaust wise would be another reason you "lost" psi. all you did was make ur system flow better.
Old Apr 25, 2011 | 04:58 PM
blacksss's Avatar
i had a full exhaust already on before i installed the kit. no codes, and yes the car still feels fine. maybe it is the weather issue.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
ernnyyes
Oct 2, 2015 05:16 PM
717ssbalt
Oct 2, 2015 04:01 PM
Stuff
Oct 1, 2015 05:47 PM
