low coolant light
Old Jan 19, 2011 | 11:08 PM
Joemaster70's Avatar
low coolant light
Everytime my car sits for long periods of time when it's Freezing out i get Low Coolant light for probably 2min or so once the car warms its all good. I have fluid in my Resoivor tank, Is there supposed to be fluid in the section below the supercharger before the car is started? There wasn't anything in that part
Old Jan 19, 2011 | 11:11 PM
Black SS/SC 06's Avatar
If you take the cap off the filler neck you should be able to see coolant cycling through when the car is running.
Old Jan 19, 2011 | 11:14 PM
CanadianCobalt's Avatar
Yea there is supposed to be fluid in there. Mine sit's about an inch up.
Like Black SS/SC said, you should be able to see it moving. I'm not sure if there is a low fluid warning attatched to the IC system though. My car got a low coolant light and I found it was a hair above the line but I added a bit more and it has not ever done it since.
Joel
yeah but when the car just started its empty is that normal??
i hope i ain't leaking
Just bought Opt b kit and Ottp H/E
why would my light come on Fluid doesn't evaporate
Old Jan 19, 2011 | 11:16 PM
No, mine was only ever empty when i was refilling it. Fill it up a tad and check if it leaks away, or just look for spots in your garage/pad etc.
Joel
Did you install the Opt B and H/E already?
Old Jan 19, 2011 | 11:21 PM
nah just bought from people on here, waiting for em. Plus it's 15 degrees outside. I work in that **** all day, i refuse to install in that weather.
Cars outside in a parking lot. Gonna be hard to see leaks
Old Jan 21, 2011 | 10:54 PM
just checked filler cap after a 45min drive home, No fluid is flowing through filler neck WTF does that mean???. My temps don't go above 180F in the car.
Old Jan 22, 2011 | 05:38 PM
called a family friend mechanic explained i might have sensor issues, IC pump might not be working, clog in cooling system. Gonna have it checked out, car sits for 20-40min temps not going above 190 but it's 15 degress outside. Also i filled up the resevior tank, and filled up filler neck 2x it has fluid in it now. it wasn't flowing superfast though. What damage could be done to my car
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Slick_Nick
Sep 28, 2015 09:15 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
