LOW dyno numbers with the stage kit...
Hey guys, I have been dynoing my car this month and I can't seem to get past 225hp and 209ft/lbs or torque with the stage 1, 2.9 pulley, and K&N CAI. Now I am getting a p0420 error once and a while which is "catalyst system efficiency below threshold (Bank1)". Do you guys think that is the reason for the low numbers? I dynod with the 3.15 and the max was the same with the 2.9. But, I did gain 15hp throughout the power band. I am just really frusturated that the car is putting out less hp with these mods than some stock cars.
Now I know that all dynos are different but that number seems a bit low. All of my pulls were in third. Any suggestions?????
Originally Posted by silverSS
the stage kit is not gonna increase power. The kit was overrated. all the kit is good for is to get rid of the CEL lights and give you a base to add some bolt on's.
ask any real racer, any real racer...
Well even with the 2.9, K&N, and a 3 inch exhaust I just thought I would have more than a 225hp max.
perhaps you had bad heatsoak, but still....idk man
with a 3" pulley alone i dynoed at 230WHP on a dynojet, so your #'s arent that off.
or possibly the pointless 3" exhaust?
Well the exhaust is in R&D for a company. I did a baseline with the exhaust off and with it on and I didn't gain a thing. Your right, the 3 inch is pointless for lightly modified cars but if you have a highly modified cobalt like maybe a intense stage 5 or you just want a good sounding exhaust then it can be useful. I mean ****....you wouldn't take a free exhaust.
yeah if its free i'd take it....then sell it!!!
Im still on the stocker, and it seems the tone is more aggresive with a few bolt-on's, so im keeping it!
2 1/4 VS 2 1/2...I dont see spending nearly $500 for a new exhaust.
totally agree with yea.
Originally Posted by cashstacker
I concur with pointless 3 in exhaust you probably are just running really rich due to stage 1. I run 3in pulley on stock injectors and it's fine.
Stage one adn 2 tunes are not the same.
But it sounds like you have a bad catt. I would have it replaced and see if that helps.
Also a catt back will help HP if the car is moded. And after the replace the manafold it will help alot more then befor. But a 3" is pointless unless your going for some big power #s.
later
later
What?!?
silverss what are you talking about the stage kits dont do anything?
i had an increase of 31.4 hp and 15.0 ft/bs of trq and have the before and after dyno charts. this was with a very hot car too.
also do you have a baseline before you did the stage kits?
or....
like everybody has been saying somethings wrong with your cat.
or....
