lowered with 3" exhaust bangin on rear bar
Old Mar 22, 2011 | 12:06 AM
ecot3c inside's Avatar
It's been happening forever now and I finally just want to say "f%*& you" to my exhaust banging on the rear cross member. What was YOUR fix? smaller tighter hangers? My idea is it will always bang unless I tighten my rear shocks to be stiffer which I don't want.
Old Mar 22, 2011 | 01:13 AM
InfraRedline's Avatar
I made another hanger for the other side of the muffler and tightened that ho way up and it doesnt do it anymore. I can literally do pull ups on my exhaust when its on the lift its so sturdy
Old Mar 22, 2011 | 12:44 PM
Rodimus_Prime's Avatar
does anyone know where i can find smaller rubber hangers than the stock ones so I can get the exhaust up higher?
Old Mar 22, 2011 | 12:46 PM
BNS06Mike's Avatar
i think im going to be in the same boat pretty soon
im lowered on coils. its stiff suspention but im getting the hahn 3in. anyone thing this is going to hit?
Old Mar 22, 2011 | 12:51 PM
07SportRedSS's Avatar
it will hit.. a good way to stop the noise is to heatwrap both the exhaust and the crossmember
Old Mar 22, 2011 | 12:54 PM
nizzle's Avatar
I had the same problem. Just took it to an exhaust shop and had it fixed last friday. He adjusted the hanger a little and put a slightly smaller hanger on it to pull it up some. It works fine now.
Old Mar 22, 2011 | 01:59 PM
Apparently hahn is redesigning that section of their exhaust for that reason. Maybe shoot them an email and see how its coming before you perchase one.
Old Mar 22, 2011 | 02:03 PM
Zero6LS's Avatar
I've been having that problem too. Where can u find a smaller hanger? My mid pipe hangs too low and scrapes when I go over speed bumps
Old Mar 22, 2011 | 02:15 PM
sjc0013's Avatar
Window Licker
Hahn is done making the exhaust, so if anyone plans on purchasing one, good luck trying to find someone getting rid of theirs
BNS06Mike's Avatar
im going to have to look into both options.
i actually just installed the Hahn on my roomates car a few months ago so I'm going to take a look at his and see where it is sitting at and what other options that i have to go with.
Old Mar 22, 2011 | 02:18 PM
Zero6LS's Avatar
The Hahn 3" cat back sounds awesome. I just sold mine tho
Old Mar 22, 2011 | 02:27 PM
nfarrall's Avatar
buy poly hangers
Old Mar 22, 2011 | 02:39 PM
sjc0013's Avatar
Window Licker
it sounds like secks!!! let me know what you guys do for solutions, planning on going lower soon
Old Mar 22, 2011 | 02:59 PM
BLAZIN07SS's Avatar
I'm too JDM for you
my custom exhaust doesn't hit. don't exactly know what the exhaust guy did but it worked damn well
Old Mar 22, 2011 | 03:00 PM
just realized when I was switching my o2 sensor that the exhaust is too long, allowing it to bang easier because it is farther down and doesn't have the bend over the rear bar exactly right, probably why my hangers are always falling off and coming loose because they don't line up right, I'm gonna go to the exhaust shop and tell them to take about 3 inches of pipe off from after the down pipe, that should finally fix my problem. It's because when they put the pacesetter header on it added to the overall exhaust length.
Old Mar 22, 2011 | 03:03 PM
BNS06Mike's Avatar
i got lucky, im about to buy the hahn and it is coming with the adjustable flange to bolt to the DP so im kinda excited about it
Old Mar 22, 2011 | 03:08 PM
sjc0013's Avatar
Window Licker
How are you getting it? They dont make it anymore........
Old Mar 22, 2011 | 03:13 PM
BNS06Mike's Avatar
im bougth it from someone last night.
Old Mar 22, 2011 | 03:18 PM
sjc0013's Avatar
Window Licker
ah gotcha, good call by you
Old Mar 22, 2011 | 03:21 PM
BNS06Mike's Avatar
yeah hopin i dont scrape or hit too hard with it when it gets installed.
Old Mar 22, 2011 | 03:26 PM
icemaid's Avatar
I had the same problem, the rubber hanger is a little to big, just had to bend the metal hanger bracket down and that stretched the rubber one so now it is nice and tight and doesn't bang any more or come loose.
Old Mar 22, 2011 | 03:30 PM
BNS06Mike's Avatar
nice and ive got the equipment to even just reposition or replace the hanger on the exhaust if needed as well. thanks
Old Mar 22, 2011 | 03:33 PM
I got the 3m backed exhaust wrap and wrapped it over the top of the rear beam. It would rub through every three weeks or so and id just apply some fresh stuff. A $20.00 roll of it lasted me a year
Old Mar 22, 2011 | 03:37 PM
countrySS's Avatar
this works for a lil bit til it rubs through the heat wrap i know i did it
Old Mar 22, 2011 | 07:39 PM
SneakyMilo's Avatar
Poly hangers are probably a good idea anyway. The stock hangers suck. Mine let the exhaust flop all over the place.
