lowest iat2 you've seen
Old Dec 4, 2008 | 03:07 PM
stonny9's Avatar
I just came back from Tennessee/North Carolina. Even in 24 deg temps and cruising on the highway I never could get the iat2 temps below 60deg. Normally when cruising for long distances i south Florida the iat2 will get to 18-20 deg above the outside temp. So I should of seen iat2 temps in the 40's according to how I run in Fl. I have no cooling mods and a stg2 pulley but the temps are fine in florida.
Is the intercooler pump set to only allow the iat2 to get to 60?
Old Dec 4, 2008 | 03:10 PM
RedEcotecSS's Avatar
I live in north carolina and my iat2 usually sits around 65-70. I have a 2.9 pulley. Maybe its just the different atmosphere conditions in different areas.
Old Dec 4, 2008 | 03:23 PM
stonny9's Avatar
On a side note I also boosted 16 lbs on the stock tune and threw a lean code.
Old Dec 4, 2008 | 03:24 PM
1badBlueberrySC's Avatar
AT WOT it's higher than that! But at WOT I usually see 100-120*
Old Dec 4, 2008 | 03:28 PM
PhantomSS's Avatar
normal driving my IAT2s are always 30 over IAT1
at WOT it is always around 135, whether it is 80 degrees out or 35. I cant get over 135 though. Even if i run it to 150 mph.
Before the H/E it was always at 160ish after WOT run and 40-50 over IAT1
Old Dec 4, 2008 | 04:51 PM
tdipowered's Avatar
how do you measure the iat2s? yea im dumb
Old Dec 4, 2008 | 04:53 PM
ShortStack's Avatar
If you have hptuners, when you log your car, it comes up to reading...
Or you can by a interceptor.
which is an electronic gauge.
Old Dec 4, 2008 | 04:56 PM
williamhvx1's Avatar
126 craker
Old Dec 4, 2008 | 04:59 PM
eckow8's Avatar
I just got my interceptor last week and I see iat2's are usually 5-12 degrees above outside temp when city driving and are lower when on the highway, usually 3-8 degrees above outside temp haha gotta love the hahn intake manifold
Old Dec 4, 2008 | 05:04 PM
Zach06CobaltSC's Avatar
damn turbo people with low iat2's lol.
If you have an interceptor and it gets really cold out, when you start your car the iat2 can be really low like 20 or 30 give or take. However once the car reaches operating temp my iat2's generally sit around 55-60 in the winter. With a hard back to back to back pull its hard to reach 100. You gotta love methanol lol.
In the summer my peak is about 130ish with the 2.8 and cruise is about 20-30 over iat1.
Don't forget that its bad to beat on these cars in the winter!! They will lean out!!
Old Dec 4, 2008 | 05:17 PM
PhantomSS's Avatar
I don't see mine lean out afr still 11.8-12ish
Old Dec 4, 2008 | 05:19 PM
If you live in an area where it gets really cold, below 40 you will see these cars lean out.
Old Dec 4, 2008 | 05:21 PM
ItalianJoe1's Avatar
How the **** you haven't done real damage yet is beyond me.
Old Dec 4, 2008 | 05:27 PM
lol i was thinking the exact same thing. Maybe he means on the stage 2 tune?
Old Dec 4, 2008 | 05:35 PM
06black's Avatar
my high of the week was just set.
42deg AIT2 after 1st/2nd pull.
36deg out side
my summer high was 103 after a solid 1-2 and 3/4 3rd gear pull
it was high 70's out.
Old Dec 4, 2008 | 05:38 PM
I just found out today... with my car NOT spraying meth I got 120* IAT2 on a 60* day
Old Dec 4, 2008 | 05:47 PM
PhantomSS's Avatar
Mine always gets 135 iat2s
Stage2
2.8
2.8 with meth
End of 3rd= same
Only thing changed was timing + maf
Old Dec 4, 2008 | 05:57 PM
INFE's Avatar
i usually see around 200 degrees
Old Dec 4, 2008 | 06:03 PM
JMAc88's Avatar
i see 0 when the car is off
Old Dec 4, 2008 | 06:04 PM
XM15's Avatar
I hope you are referring to coolant temps. lol
Old Dec 4, 2008 | 06:39 PM
INFE's Avatar
Nope. Superchargers are
Old Dec 4, 2008 | 07:15 PM
No, he's a local guy. Car is STOCK TUNE, with a stage 2 pulley. I installed the pulley for him
Has that magic 'fast banana' treatment.
Honestly, my car used to have that setup nearly 3 years ago, and it ran hard as ****.
Old Dec 4, 2008 | 07:24 PM
ColeJJones's Avatar
Bannned
my highest ever iat2s is when i ran ssmokin's z06. top of 4th i had 206* iat2s.
Old Dec 4, 2008 | 08:25 PM
I fixed my meth issue.... had 113* IAT2's at WOT in 3rd at 100+ mph
Old Dec 4, 2008 | 08:27 PM
I win...
235+ in 4th gear.
