LS4 Throttle body install
Old Mar 9, 2009 | 04:51 PM
  #51
ralliartist's Avatar
thanks for the heads up bry, good to know!
Old Mar 9, 2009 | 04:55 PM
  #52
Area47's Avatar
Rent me! per hour
when you have a dyno at your disposal. you try new things and find out what does what.
Old Mar 9, 2009 | 05:16 PM
  #53
ebristol's Avatar
Originally Posted by Area47
the tb scaler has zero affect on performance. all that does is control the speed of closing on the tb itself.
There needs to be a way to control the speed of OPENING the tb based on throttle position at low rpms or low throttle.
Unless driver mod 2.0 handles that...
Old Mar 9, 2009 | 05:18 PM
  #54
ecotecon18s's Avatar
the m62 doesn't need a ls4 tb on it. it doesn't move enough air. the tvs however, when you start dropping pulley sizes and moving more air can benefit from it. there are some of us who are going wacky with stuff, so more air is good
Thanks.
Old Mar 9, 2009 | 05:25 PM
  #55
domin8_gt's Avatar
Ah, there is hope for the LS4 TB sitting in my trunk right now. Thank you guys for all your hard work. Now I just need OTTP to finish their CAI.
Old Mar 10, 2009 | 01:14 AM
  #56
Rodimus_Prime's Avatar
So what about raising the scaler even higher say 5100? Would that make things better?
Old Mar 10, 2009 | 01:56 AM
  #57
spike's Avatar
saved
Old Mar 10, 2009 | 11:33 AM
  #58
I'm at a standstill for a few days because I'm out of methanol, after that I can post some logs for you fellas, actually I have a few already from the rough tune I'll see if I can get them up later
Old Mar 10, 2009 | 11:51 AM
  #59
Deathscythe's Avatar
windshield washer fluid not good enough?
Old Mar 10, 2009 | 11:56 AM
  #60
I dont use that ****, I use snow performance boost juice 50/50 water methanol, no impurities. Washer fluid is 10 percent methanol, 50 percent water and 40 percent "other". I do not like putting "other" through my engine. Not to mention using washer fluid has ZERO affect on AFR and didn't seem to prevent knock very well. The snow stuff richens me by a half point, which lets me use alot less injectory duty.
Old Mar 10, 2009 | 12:19 PM
  #61
ShortStack's Avatar
Well, you should use more than just Windshield fluid...
Im sure you have heard of HEET?
If you find the stuff that DOES NOT have bug remover in it, then its deffinatly wayyyy less impurities.. as i think that 40 percent mark is a little high anyway.
Old Mar 10, 2009 | 12:25 PM
  #62
ebristol's Avatar
Some washerfluid contains up to 49% methanol. You just need to know what you are doing and know where to look. You can get Peak -20 at Walmart which contains 33% methanal...
But if you like to pay more for the same stuff go for it.
Old Mar 10, 2009 | 03:44 PM
  #63
Area47's Avatar
Rent me! per hour
methyl alcohol
hard ware store.
Old Mar 10, 2009 | 03:53 PM
  #64
ShortStack's Avatar
I think i found some at a hobby shop, too.
Old Mar 10, 2009 | 04:02 PM
  #65
so the stuff at the hardware store is that pure methyl alcohol, i dont want anything that has other **** in it
Old Mar 10, 2009 | 04:28 PM
  #66
HEET is 98% methanol i believe...i use about 3 bottles of it and a gallon of distilled water...
Old Mar 10, 2009 | 04:59 PM
  #67
StevesBlack06's Avatar
saved for future use... i have a ls4 on the way. hope i can get this thing figured out.
Old Mar 10, 2009 | 08:49 PM
  #68
Heet also has anti freeze in it as well
Old Mar 10, 2009 | 08:52 PM
  #69
tdipowered's Avatar
awesome install and nice looking car man
Old Mar 10, 2009 | 10:02 PM
  #70
thanks, ah upon further research yellow bottle Heet is 99% pure methanol, this is awesome, but I need to find a cheaper bulk source of it
:edit found a local supplier for pure methanol, way cheaper than im paying now
Old Mar 11, 2009 | 01:25 AM
  #71
ls1fbody's Avatar
Haz l33t wheelz.
^care to share?
Old Mar 11, 2009 | 06:11 AM
  #72
yep. $1.XX per bottle, plus under $1 for a gallon of distilled water. Just a couple bucks to fill the tank.
Old Mar 11, 2009 | 09:42 AM
  #73
I can get methanol now for 5 bucks a gallon, water for practically nothing so basically instead of paying 7.50 a gallon for the snow stuff i can make it for half that
Heet is 2 bucks a bottle for only 12oz id need about 10 of them to get a gallon thats even more expensive than what im paying now
Old Mar 11, 2009 | 09:46 AM
  #74
R&C_rallySS's Avatar
Your always doing something crazy and different...I hope it works out for you and one day it should all pay off. I want to see 320 whp out of that thang with meth and perfect tune!
Old Mar 11, 2009 | 09:51 AM
  #75
Darkmanx's Avatar
gheez ....
