LSJ dipstick lenght
Old Mar 4, 2011 | 04:02 PM
Spanky's Monkey's Avatar
LSJ dipstick lenght
I need a huge favor from one of you guys can you measure the lenght of the dipstick from the base of the cap to the bottom of the bulb on the tip. thanks in advance.
Old Mar 4, 2011 | 06:09 PM
mrbelvedere's Avatar
u loos it
Old Mar 4, 2011 | 06:23 PM
no, trying to find out if there is a difference in lenght between the LSJ and L61 sticks. i have the LSJ oil pan on my ride and even with 6.5 quarts of oil in it does not register on the stick.
Old Mar 4, 2011 | 06:34 PM
jonathan923's Avatar
mine takes more than 6.5 to register to half on the stick...
Old Mar 4, 2011 | 06:36 PM
05Slowline's Avatar
I'll swap you I got a 2.2/2.4 pan
But yea it's like 6.5 quarts and then another .2-.4 quarts
Old Mar 4, 2011 | 06:51 PM
okay cause before the trans failed i do recall adding at least 7qts to get it to show about halfway up the line. that sounds about right then. I was just worried i was adding to much oil and flooding the turbos oil return line installed on the oil pan.
Old Mar 4, 2011 | 09:42 PM
xxxxsh4d0wxxxx's Avatar
Yeah a normal oil change is like 6.5-6.75 quarts.
And what the hell.. 7 quarts to show HALFWAY? That is wayyyyyyyyyyyyyyyyyy off brother.
call ced and ask if they r different part numbers
Old Mar 6, 2011 | 06:20 AM
Speedytec's Avatar
I found a difference in length between the LSJ and European Z22SE (=L61) dipstick, so check this! (forgot to note my measurements...)
Old Mar 6, 2011 | 11:36 AM
thanks speedy i'm waiting to get ahold of local lsj owner.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
