Is the LSJ harmonic balancer the same as a 2.2?
Old Apr 24, 2009 | 08:14 AM
ArielAtom300's Avatar
Found a 2.2 ATI harmonic balancer and was wondering if it is the same as the 2.0 LSJ. ATI could not tell me. Anyone know for certain yes or no?Thanks.
Old Apr 24, 2009 | 09:05 PM
Ryze's Avatar
pretty positive, NO..
Old Apr 24, 2009 | 09:18 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Ask 06blackg85ss because Paul is using an ATI in his new build.
Old Apr 24, 2009 | 09:20 PM
silverfae7's Avatar
No, the lsj balancer uses a 6-rib belt. the 2.2 uses a 5-rib belt. you can use the lsj balancer on the 2.2, but not the other way around.
Old Apr 24, 2009 | 09:28 PM
The ATI site states
Originally Posted by ATI
Supercharged Applications
The ATI Super Damper works with either a six or eight groove setup with no modification. While the stock setup only requires a six groove pulley system, the ATI Super Damper features a lightweight 2024 aluminum outer shell designed to accommodate 8 groove belts commonly found on aftermarket superchargers
http://www.atiracing.com/links/pr/ecotec/index.htm
Old Apr 25, 2009 | 12:44 PM
what exactly are the advantages?
Old Apr 25, 2009 | 05:42 PM
ralliartist's Avatar
how much lighter is it than the stock harmonic balancer and has there been any reports of problems with the ATI dampers?
Old Apr 25, 2009 | 10:05 PM
qwikredline's Avatar
the ati damper is not lighter. it is heavier with a damper. the lightweight crank pully's cause havoc with lsj timing chain/ lower crank gears; they wont last long. a damper pulley with a lightweight clutch/flywheel is a good idea. send 06blackg85ss a pm
Old Apr 26, 2009 | 07:50 AM
kinda threw me off talking about lightweight crank pulleys going to clutch/flywheels.
so lightweight crank pulleys and alt pulleys are causeing probs with our timing chain/lower crank gears? i havnt seen anything on here about that yet.
Does this unit replace the crank pulley?
Old Apr 26, 2009 | 09:31 AM
I had a light weight pulley, guess who's, on my DD and it crapped out after 400 miles. Yes I was really pushing the pedal hard and I shifted and went for it. The rest is history and most know the outcome of that.
I will not use an aftermarket, light weight pulley again, I will look at using this ATI for the DD.
Old Apr 26, 2009 | 09:35 AM
their pulley was junk from the get go tho, much like the company. Im looking at getting MRZ's pulley.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 28, 2015 12:51 PM
