LSJ Important Warning!
Old Aug 20, 2008 | 06:37 PM
  #51
Area47's Avatar
Rent me! per hour
there is no point in upgrading pumps. the place i got the pump from is the same place i got the cobra h/e and factory svt brackets for 25 bucks.
local forum
Old Aug 20, 2008 | 06:43 PM
  #52
07touringcoupe's Avatar
Originally Posted by 95cam86roc
ahhh gzzz... i havent drove my car forever.... all this talk is making me paranoid... better go out n check the pump.
Make that both of us!
Old Aug 20, 2008 | 07:02 PM
  #53
Psykostevo's Avatar
Originally Posted by drop-n-destroy
Isn't this pump failure covered under warranty?
If your car is actually still under warranty! How many you think could get in under warranty?
Originally Posted by flash13brandon
I dont like this article. It makes me worried that my pump is gonna go soon. Ive been running for about 2-3 weeks with my CX h/e on. Is the filler neck supposed to be filled to the top or is it supposed to be like an inch from the bottom?
Like an inch from the bottom.
Last edited by Psykostevo; Aug 20, 2008 at 07:02 PM. Reason: Automerged Doublepost
  #54
Sythen1678's Avatar
I have a question about the Iat2's, I know it deals with temperature, but how do you find them out? are they on the information screen in the tach and mph screen? Becuase my temp gauge reads 190 and 200, and if thats the iat2's then i need to fix my pump ASAP!!
Old Aug 20, 2008 | 07:04 PM
  #55
Psykostevo's Avatar
No way to check the IAT2 without aftermarket equipment.
Old Aug 20, 2008 | 07:07 PM
  #56
Im not understand this. Is that a yes! I mean it should be
Old Aug 20, 2008 | 07:08 PM
  #57
Psykostevo's Avatar
If your car is under warranty, then YES it will be replaced. Look around the boards, not many of us qualify as "Under Factory Warranty"
Old Aug 20, 2008 | 07:14 PM
  #58
drop-n-destroy's Avatar
Mine is an 07 so it has 5 year/100K power train warranty. IDK if it's covered under power train. Heck... let the motor blow so I get a brand new one.
Old Aug 20, 2008 | 07:15 PM
  #59
Oh ok you are refering to the mods and/or aftermarket work done? cuz yea i see. It looks like everyone is it least stage 2 except me
Old Aug 20, 2008 | 07:17 PM
  #60
You're way behind man.
  #61
It wont be that easy. I really dont know any dealer to do warranty work. They always bullshit around and find the littest thing to bam at you
  #62
flash13brandon's Avatar
Stage 2 does not void warranty tho...will an afternamrket h/e void any warranty on the pump?
Old Aug 20, 2008 | 07:20 PM
  #63
I know i get 2 for that. Thats cool tho. I just got my SS 1 month ago, so i will be up there in no time
Id say yea seeing as tho its a aftermarket part and the failed part would be the pump and thats the pump for the H/E. They would try to find a way to point you the blame
Last edited by 07touringcoupe; Aug 20, 2008 at 07:20 PM. Reason: Automerged Doublepost
Old Aug 20, 2008 | 07:22 PM
  #64
Psykostevo's Avatar
Fo sho!
Old Aug 20, 2008 | 07:24 PM
  #65
well since I don't have h/e or any other cooling mods, then I'm covered.... I guess
Old Aug 20, 2008 | 07:26 PM
  #66
C0baltWithM0ds's Avatar
Originally Posted by hatrickstu
mine didnt work for a long time before i noticed. hit it with a hammer and has worked since
lol works everytime its a mans greatest possesion
Old Aug 20, 2008 | 07:28 PM
  #67
Psykostevo's Avatar
I used a hammer to repair my volvo, and I break out the rubber mallet when I need to be "gentle".
Old Aug 20, 2008 | 07:59 PM
  #68
95cam86roc's Avatar
Well i went out n checked my pump... Opened the hood to listen for the faint whine. I heard a faint whine so i guess im good to go.... If not, its a good thing its parked.
Old Aug 20, 2008 | 08:02 PM
  #69
Psykostevo's Avatar
Why did you just listen for a whine? Pop the cap and LOOK to see if the water is flowing.
Old Aug 20, 2008 | 08:04 PM
  #70
restonSS's Avatar
hang on, do you mean to resevoir in the front of the engine or the back right?
Old Aug 20, 2008 | 08:12 PM
  #71
95cam86roc's Avatar
Check for what water? If your talking about the coolant tube in front of the supercharger... i seen the coolant moving through it.
Old Aug 20, 2008 | 08:14 PM
  #72
auggie_ss_phx's Avatar
I can't wait to get you on the dyno Saturday. Woohoo!
is there something i should know about both of you guys???
Old Aug 20, 2008 | 08:17 PM
  #73
Karo's Avatar
Anyone care to list a part number of an OEM Pump or a link to buying a new one off eBay for $90.00 dollars?
Thanks
-Karo
Old Aug 20, 2008 | 08:27 PM
  #74
Sythen1678's Avatar
i just checked mine, and there is no flow...... 40k miles brb with hammer trick!
HAHA, i added water and started the car, and the mixture stayed clear no movement... i jacked up my car turned it on, taped on the pump with a ratchet not hard at all, get out look at the coolant and sure enough it started mixing, and flowing! wonder if thats why my car has been running so shitty?
Last edited by Sythen1678; Aug 20, 2008 at 08:27 PM. Reason: Automerged Doublepost
Old Aug 20, 2008 | 08:33 PM
  #75
jackjohnson_218's Avatar
Its the front one. Here's a good vid of no flow from one of the redline forum guys.
http://www.youtube.com/watch?v=82vw6ZZKElw
