LSJ Important Warning!
Old Aug 21, 2008 | 11:48 AM
  #126
Psykostevo's Avatar
Originally Posted by Sythen1678
so your saying that the pump that pushes coolant around the system only deals with Iat2's? i just want to make sure that this pump is not the reason that temps on my normal gauge are going up because if my Normal temp goes up im sure my Iat2's will as well...
If you live in Arizona and want me to drop your coolant temps PM me.
Old Aug 21, 2008 | 01:30 PM
  #127
rrutter81's Avatar
Originally Posted by Omega_5
I wasn't sure either, until one day I unplugged my MAF to be sure I was in VE for tuning, and sure enough my IAT1 stopped reading.
i so want to steal your sig
/threadjack
Old Aug 21, 2008 | 01:32 PM
  #128
Omega_5's Avatar
/threadjack
Go ahead.. CSS needs natural selection bad...
The more Darwin supporters, the better.
now /threadjack...
Old Aug 21, 2008 | 01:34 PM
  #129
CptTheAlex's Avatar
Originally Posted by hatrickstu
mine didnt work for a long time before i noticed. hit it with a hammer and has worked since
F*cking sweet
Old Aug 21, 2008 | 02:01 PM
  #130
chris88z24's Avatar
Checked mine.. I started the motor and started to loosen the cap, and the fluid started moving. Mine's good, 20k on the clock. I'll be sure to check it from time to time though
This should be a sticky.
Old Aug 21, 2008 | 02:03 PM
  #131
invisible's Avatar
Check it when you get close to thirty.
Old Aug 21, 2008 | 02:58 PM
  #132
Corvettespirit's Avatar
GRABBER BLUE MUSTANG GT
Gm Document Id 1471156;the Supercharger Has An Integrated Intercooler.cooling The Air Enhances The Effectiveness Of The Supercharger.the Intercooler Uses Conventional Coolant In A Separate Sealed System From The Engine Cooling System. The Intercooler System Has A Radiator,a Reserve Tank/filler Neck,a Preassure cap,attaching Hoses,and A Pump Capable Of A 26 Liters(7gallons)per Minute Flow Rate.the Pump Is Commanded On,by The Control Module,whenever The Engine Is Running.
Old Aug 21, 2008 | 03:10 PM
  #133
Area47's Avatar
Rent me! per hour
none of us never knew that.............
::turns to key on position::
hey, the pump comes on!
::smack::
Old Aug 21, 2008 | 03:33 PM
  #134
Coop's Avatar
Is there a TSB or recall on this? I would think there would be.
Old Aug 21, 2008 | 03:36 PM
  #135
Mss26's Avatar
::smack::
Report Card: Does not play well with others.
But seriously, if the pump is always on when the car is running, then why were people talking about messing around with the settings in HPT?
Old Aug 21, 2008 | 03:39 PM
  #136
hatrickstu's Avatar
hey nice fail, and not even at 200 posts yet. we are talking about usingHPT to turn it on
because you can run it at the track when the car is off. thus keeping the coolant flowing and cooling the sytem down. OR if you are smart, you have odne the reservoir swap and can introduce new cold water into the system and drain out the hot stuff while having the pump running.
Last edited by hatrickstu; Aug 21, 2008 at 03:39 PM. Reason: Automerged Doublepost
Old Aug 21, 2008 | 03:41 PM
  #137
Tomtwtwtw's Avatar
What people are generally doing in HPT is enabling fans and IC pump to be on while in accessory mode, rather than letting key sit in the on position. Good for hanging out in the staging lanes between runs down the dragstrip.
Old Aug 21, 2008 | 03:44 PM
  #138
Area47's Avatar
Rent me! per hour
dyno purposes. track purposes. bleeding air without wasting gas.
Old Aug 21, 2008 | 03:53 PM
  #139
Mss26's Avatar
Okay I see guys, that makes perfect sense.
As far as cooling goes, I know some people have cobra heat exchangers, but why don't more people have the aftermarket heat exchangers made for the cobra?
Like a true dual-pass heat exchanger such as the AFCO Pro Series?
http://www.rpmoutlet.com/03cobraheat.htm
Old Aug 21, 2008 | 04:16 PM
  #140
Area47's Avatar
Rent me! per hour
limited space for one. the one i would love to have is made by canton.
Old Aug 21, 2008 | 04:17 PM
  #141
hatrickstu's Avatar
area im being for reals, if you have the room, do the res swap...
hell put it in the trunk
Old Aug 21, 2008 | 04:24 PM
  #142
LSJ_47's Avatar
I had this same issue. I knew more about the damn thing than the three GM dealerships in town combined....
Took them 4 hours to replace it. My warranty expired well before this. They covered the repair for the pump on warranty, even though I didnt have it.
I did countless pulls with this condition... I did 15 runs at a track too! didnt break, just got slow as hell once it got hot. But still probably wasnt a good thing for me to do. Didnt figure it out until about a month of this happening, so maybe I got lucky.
Old Aug 21, 2008 | 04:29 PM
  #143
Mss26's Avatar
The AFCO Pro is slightly smaller than the "large" CX Racing Ebay... The AFCO also looks to be built quite a bit better and of course more expensive ($299).
I'm pretty sure I'm gonna buy the AFCO as a replacement (not running in-line with the stocker) and test it out.
Old Aug 21, 2008 | 04:30 PM
  #144
invisible's Avatar
Why not run it in line though?
Old Aug 21, 2008 | 04:34 PM
  #145
rrutter81's Avatar
fan on during accessory?
do show?
  #146
Mss26's Avatar
Well they are marketed as "replacements".
But really I don't know physics or fluids so if someone explained how or why it would make sense to run it inline I would.
Old Aug 21, 2008 | 04:38 PM
  #147
ShortStack's Avatar
Because you have 2 coolers instead of one? And Its not hard to mount the cx racing one infront if it, if thats the problem... cause i noticed its the only one that says "stock mounts" thats even worth buying ..
It would be like a dual pass but not.. you know?
Old Aug 21, 2008 | 04:41 PM
  #148
hatrickstu's Avatar
do show?
go to hpt/system/fans/FAN output control vs state
1's across the top
0, then 1's across second row
0's across in 3rd
for hte track all 1's in first 2 rows
  #149
DoMiStIc_RuSh_06's Avatar
So what if My pump was to go, could I take it somewheres and get it rebuilt with stronger better parts. Would that be a benefit to me? Just a question, has anyone tried this.
Old Aug 21, 2008 | 04:42 PM
  #150
ShortStack's Avatar
For the price to get it rebuilt will probly be more than to just get a new one... my guess ..
unless you know someone who works in a shop and gets the parts cheap...
