lsj intake mani gasket
Old Mar 16, 2010 | 11:20 PM
rhynoj's Avatar
What style gasket does the lsj use were the intake manifold meets the head? is it reusable if I were to remove the manifold? is this gasket the same on all ecotecs? any info will be a great help.
thanks
Old Mar 17, 2010 | 03:08 AM
Zach06CobaltSC's Avatar
This is the gasket that you will want to be using and luckily the price just dropped recently.
http://www.crateenginedepot.com/stor...P1723C137.aspx
If you have an 05/06 you will want to upgrade to this "new" upgraded intake manifold gasket that will help the issue of the dipstick popping out. I highly recommend replacing your intake manifold gasket if you are taking off the intake manifold.
Old Mar 17, 2010 | 03:12 AM
ItalianJoe1's Avatar
It's a single layer metal gasket, totally re-usable unless damaged, but as Zach said, if you have the early style, you should buy a new one and get the upgraded one. Also, if it's been off a couple times it tends to flatten out and may not seal as well as it should, although I never personally had a problem in the many times taking manifolds off. It's not expensive though.
Old Mar 17, 2010 | 03:05 PM
Frew's Avatar
when I went from the stage two pulley to a 2.9 like a year ago, I started having this issue, replaced the gasket with the updated design, problem solved.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
