LSJ with L61 build (crank sensor???)
Old Sep 5, 2016 | 09:15 PM
PatZ24's Avatar
Question LSJ with L61 build (crank sensor???)
Hi Guys,
i think you can help me to solve my problem. I have build new engine for my customer. The car is 2005-07 Cobalt SS LSJ.
I have forged L61 2007 HHR 58x engine block with stock crankshaft, eagle rod and wiseco. I have use stock ljs crank sensor on the L61.I have use LSJ head.
When i try to start i have some explosion but the engine wont start..... The reluctor wheel have both 58X. I im really confused about that.........
Do you think my crank sensor are bad? Can i use L61 3 wires sensor with 2 wires conversion for LSJ pcm???
Thank you and scuse me for my bad english!
Pat
Old Sep 5, 2016 | 11:40 PM
Sharkey's Avatar
the reluctor wheels on the 07+ l61 and the lsj are both 58x, however they are clocked differently. the missing teeth on the wheel are not in the same spot in relation to cylinder 1 top dead center. as a result the ocm thinks the engine is in a different spot than it is, and hence why it wont start.
im not sure of a work around for this. you might have to build an external crank trigger setup, or swap the entire wiring harness and computers.
Old Sep 6, 2016 | 02:20 PM
you need an external crank trigger set up like stated above or build the right engine using the lsj crank, rods, and pistons
Old Sep 8, 2016 | 07:29 AM
mrbelvedere's Avatar
you need to get a lsj relucter wheel and line up the dead spots and redrill new holes in the l61 relucter and bolt it on with the new holes
on the crank if its a stock crank it is not a forged unit
Old Sep 9, 2016 | 05:54 PM
Speedytec's Avatar
Did you guys actually measure a later model L61 58x crankshaft and compared the trigger wheel with an LSJ crank??
I know the 2.4 crank timing has some 12 degrees difference, but here in Europe the later L61 engine with 58x trigger is called a Z22YH engine. (L61 = Z22SE).
We found that the Z22YH trigger timing is identical to an LSJ crank.
You can check the trigger marks with a timing wheel on the crank pulley (118-119degrees), but much easier to do like this:
- remove the crank sensor from the block, so you can see the toothed wheel. Maybe use a mirror and a flashlight so you can look in line with the bore.
- put the crankshaft pulley at TDC position mark. Remove the plugs so you can turn the crank easier. You should see 1 tooth almost at the center of the bore. It can be a little higher/lower than center, as the pulley has a bit play on the crank, but this is your 0 degrees tooth.
- now rotate the crankpuley slowly ANTICLOCKWISE and count echt new tooth that rotates through the center till you come to the last tooth before the trigger gap.
- each new tooth is 6 degrees rotation (360/60) and we counted 20 for an LSJ crank. So that's 20x6 = 120degrees.
Easy!
Olybaltss
Mar 9, 2016 03:22 PM
SSMiKE8
Feb 22, 2016 10:54 AM
Eddie
Nov 29, 2004 03:50 PM
JonyyB
Nov 24, 2004 06:10 PM
turbostang
Nov 11, 2004 10:49 AM
