lsj manifold pcv replacement?
Old Mar 10, 2013 | 12:46 PM
1LowLS's Avatar
Is there a way to replace the pcv in the intake manifold? Mines no bueno
Old Mar 10, 2013 | 12:48 PM
BankerBalt's Avatar
the boost nipple? you could probably tap it and put an npt threaded nipple on it
Old Mar 10, 2013 | 01:08 PM
Validater's Avatar
No. he means the PCV valve between #2 and 3 cylinders. You should be able to buy it. I think I recall seeing it somewhere. I do forget where though sorry.
Old Mar 10, 2013 | 01:45 PM
1LowLS's Avatar
Correct.mine is stuck open pushing boost in the crankxcase and throwing my afrs l over the place.pulled the manifold off last night and cleaned it which worked for 30 minutes and it went right back to how it was.I thought about blocking it and drilling another nipple on the valve cover.
Old Mar 10, 2013 | 02:14 PM
efren6057's Avatar
Yes you can, Tom@ced sells them. I actually bought a new one from him and replaced mine with a new one. They aren't expensive at all. Just take out the old one and put in the new one and that's it.
Old Mar 10, 2013 | 02:20 PM
1LowLS's Avatar
How do you get it out. I was looking at it and coildnt figure it out.
Old Mar 10, 2013 | 04:06 PM
efren6057's Avatar
Use your finger to twist and pull it out or just grab a flathead screwdriver and gently pry it out than just push in the new one.
Old Mar 10, 2013 | 07:41 PM
Speedytec's Avatar
pressed-in with an o-ring seal. Twist and pull it out. (Think it's also a saab 9-3 part.)
Old Mar 10, 2013 | 07:55 PM
1LowLS's Avatar
I'm not finding it on ced :/
Old Mar 10, 2013 | 09:07 PM
efren6057's Avatar
You have to call Tom@ced. He'll look it up an order one for you.
Old Mar 10, 2013 | 09:29 PM
1LowLS's Avatar
Lame
Old Mar 10, 2013 | 09:47 PM
chris88z24's Avatar
There's a PCV valve on the LSJ?
Old Mar 10, 2013 | 09:57 PM
BankerBalt's Avatar
this, i'm confused
Old Mar 10, 2013 | 10:55 PM
efren6057's Avatar
It's located on the intake manifold itself, it's between the 2nd & 3rd intake holes.
Old Mar 10, 2013 | 11:33 PM
1LowLS's Avatar
Exactly. I cleaned mine and it was perfect,running strong for about half hour and now its all screwy again.ill just have to go to a dealer Tuesday.I have a new gasket coming in as well.when it sticks open,its pushing oil through the top breather in to the intake.catch can is something I'm looking in to as well.burns oil pretty bad when it sticks open.
Old Mar 11, 2013 | 12:15 AM
mrbelvedere's Avatar
12786376 is the part number and isn't a pcv valve it is a check valve or as gm calls is a intake manifold tuning
Old Mar 11, 2013 | 11:17 PM
OttawaMark's Avatar
Not this one eh?
Valve PCV 55557180
Old Mar 11, 2013 | 11:19 PM
nhanson's Avatar
Probably will replace mine when i take the manifold off to seal up my junk dual pass.
Old Mar 11, 2013 | 11:24 PM
1LowLS's Avatar
It looks like that but it doesn't say what It's for.
Old Mar 11, 2013 | 11:26 PM
nhanson's Avatar
Thats what you need...i remember what it looks like.
Old Mar 11, 2013 | 11:32 PM
OttawaMark's Avatar
Figured, Tom@CED is lightning fast and checks in regularly....dude should get a medal.
Old Mar 11, 2013 | 11:40 PM
that is a sku number not a part number what I posted is directly from the parts break down
Old Mar 12, 2013 | 12:39 AM
1LowLS's Avatar
Sku number worked better than the part number lol
DarrenGC
Dec 24, 2021 01:55 PM
patooyee
Oct 15, 2015 05:11 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
