M62 cooling
M62 cooling
I just picked up a new car with the m62 supercharger kit. It needs cooling bad!
Im wanting to do the best I can for my cooling so right now my idea is:
ZZP option B
pump
ZZP dual pass endplate
But not sure about what H/E to run.
I know the griffin is the best but it is out of my price range so im looking for the next best.
Im stuck between the ZZP S3 and the larger CX racing H/E's
Does anyone have any input??
ZZP option B
pump
I don't have zzp's stuff but what you got listed is pretty much everything you'd need for cooling. Some people will say meth but that a performnace added as well.
Try looking at OTTP's H/E, I have it and it works great!
I will be getting meth in the future for sure once I pulley down. I first need to learn to tune so I can tune for it.
Im still on the stock pulley on the gm reflash..Its a cav BTW. But im able to run the 3.1 pulley with good cooling mods on the stock reflash
I have both and what I found was the CXracing unit cooled slightly better. It is however a PITA to install properly and you need to remove the stock HE if you don't want it dragging on the ground where as the ZZP is a piece of cake to install and made to fit. I'd say go for the ZZP. OTTP's stage 1 unit isn't even a proper air/water cooler and it weighs more.
Also look into the ZZP Phenolic spacer, your temps will be way better. With opt. b, dual pass, h/e and the spacer my temps are about 10-12 degrees different. After pulls the temps recover super quick too.
I work with methanol on a daily basis. I know it's affects on water, ice and it's combustibility properties. I'm pretty sure that they won't tell me something I don't already know.
Plus if you want it just for a cooling mod use the 50/50 mix. if you use 100% meth for just cooling you are throwing money away.
Even at 50/50 with water there is still more than a little bit of performance in it
So this is what a proper air/water core looks like? Sure looks a lot like a air/air to me. I do like the dangly hanging off the bottom ready to get smashed off on the first speed bump you encounter though.
I guess every vehicle radiator made is improper then.
Thats an air to air core and isn't the current core we run and we haven't ran it in over 2 years....The picture is just outdated. Can you believe that or do I need to take you to school?
OTTP Stage 1 Heat Exchanger - Over The Top Performance
looks the same to me lol....or u could just go to frozenboost and buy it and make some brackets....
This is the zzp stage 1 which is the exact same as above with brackets welded on. Cobalt & Ion ---> ZZ Performance
Both of them use an air to air core and are more expensive than our kit that use's an air to water core.
I brought it in while discussing air to air cores and which company sells them. So did you technically because the frozen boost core is the same core as zzp. If we are comapring us made products instead of the cheaper chinese ones we can then talk about the griffin heat exchanger that is only available from us, it is the top dog of heat exchangers.
See the difference is, zzp says this is a cheap pos from china, doesn't pass it off as this is a great piece check out this nice drain thing that's going to come open and break off whenever you hit a bump lol.
