m62 pulley removal
Old Mar 16, 2010 | 11:30 PM
rhynoj's Avatar
m62 pulley removal
Im having some trouble removing the pulley from the blower on my 06 ss/sc. The car has 88,xxx kms on it. i have the blower removed from the engine and an impact gun on shop air wont pull it off with a 3finger gear puller. Ive tryed repeted soakings with penatrating oil and lightly heating the pulley before/during using the impact and puller. any info will be appriciated.
Old Mar 16, 2010 | 11:46 PM
bluecobaltss06's Avatar
Do you have a press? Idk if I would use a puller like you're using. Try this. http://www.zzperformance.com/cobalt_...=199&catid=142
Old Mar 16, 2010 | 11:57 PM
Cefaln452's Avatar
mine didnt budge the first time either... while you have pressure on it. take a torch and SLIGHTLY heat the pulley. it will pop almost immediatly then finish pullling it off
Old Mar 17, 2010 | 04:43 PM
rhynoj's Avatar
tryed it, no go. and im scared to try it too many times because the repetitive expanding and contracting of pulley may cause the pulley to shrink even more making it that much more difficult to remove... ever here of anybody having to cut a grove near the taper on the pulley and split it with a coal chissel? thats the only other way i can think of...
Old Mar 17, 2010 | 05:04 PM
JapEatr's Avatar
South Central *********
3 way puller is the wrong tool to use, and it will take some force put break it loose by hand
press is only other option
Old Mar 17, 2010 | 10:06 PM
G11's Avatar
G11
ya i had the same issue but then put it on a press and it popped right off
Old Mar 17, 2010 | 10:50 PM
Stiner's Avatar
Hydraulic press + heat. Sometimes the stock pulley is retarded hard to get off.
Old Mar 17, 2010 | 10:55 PM
thedude411's Avatar
we used a 3 way puller to get my pulley off... u guys must be pussies lol
and by we i mean matt lol
Old Mar 17, 2010 | 10:57 PM
Stiner's Avatar
some are easy some not so much I've done about 10 of them
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
goaliemo
Sep 28, 2015 01:37 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
