Machine gun fire at WOT
That is what my car sounds like at WOT. I stepped down to 2 step colder plugs the other day and gapped them at .029. I got bored today and gapped them at .032 to see what would happen. Well when I go WOT it sounds like a machine gun fire and the car goes no where. So I gapped them back and I get the same thing. Gapped them to a .026 and I get the same thing. I put the old plugs in which are a single step colder plug and I still get the same thing. Any ideas what is causing this?
My 2.2 S/C automatic does this now and then. It only happens when the car is in 4th gear and if I'm going up hill and I give it more gas and it starts making that noise. To avoid it now I just blip the throttle and it downshifts me and everything is fine then. I've always been curious as to what it was though.
What I'm trying to figure out is what I am hear is spark blow out or something else because it's way more intense.
Regap your plugs to the way you had them.
Still on stock valve springs. I don't think anything broke. It almost sounds like timing. Wondering if that e85 isn't really e85 with it this cold. I'm gonna try and get ahold of mdub.
He helped me with my misfire problems so i would def have him look at a log before anything else.
i'm willing to bet that if your wideband were working, you'd be watching it go way lean.
whats your fuel system set up like?? almost sounds like the canister is uncovering and not pulling fuel. or youre getting some sort of fuel cut.
i know that if i have less than half a tank i can't go wide open or else the canister will uncover and that same situation will happen.
