made up my mind
Old Dec 26, 2010 | 03:41 PM
DEZZIE41's Avatar
made up my mind
finally made up my mind
all from zzp
3.0
60's
heat exchanger
and a custom tune
Old Dec 26, 2010 | 03:42 PM
Billig ss/sc's Avatar
Why just a 3.0"?
Old Dec 26, 2010 | 05:09 PM
DEZZIE41's Avatar
cause the heat exchanger aint going in right away
Old Dec 26, 2010 | 05:10 PM
Bluelightning's Avatar
Got Bewst?
I ran an OTTP stage 2 (2.8") most of the summer with no cooling mods. You're car isn't going to blow up. It will just heat soak faster. Go 2.8".
Old Dec 26, 2010 | 05:11 PM
CanadianCobalt's Avatar
I ran my 2.8 without a HE for a couple weeks, it's cold up here in Canada right now as you know. Just don't do back to back to back etc pulls if your doing it haha.
If you use ZZP you might as well just get the oversized tensioner, their belt isn't a GM one apparantly.
Joel
Old Dec 26, 2010 | 05:12 PM
I have a TVS with a 2.9" and just a h/e for cooling and I'm okay. Temps are a little scary in the summer after multiple runs though lol
Old Dec 26, 2010 | 05:13 PM
blk06cbltss's Avatar
zzp belt does suck and like i told you befor you can mob with a 2.8 and no h/e
Old Dec 26, 2010 | 05:15 PM
Got Bewst?
A heat exchanger isn't going to bring you're IAT2's down. Maybe cruzing down the highway. Your temps just arent going to climb as fast and will recover much faster
DEZZIE41's Avatar
k fine lol 2.8 60s heat exchanger lol
Old Dec 26, 2010 | 05:17 PM
Got Bewst?
There ya go haha
Old Dec 26, 2010 | 05:18 PM
DEZZIE41's Avatar
what size cooler should i get though and with the heat exchanger do i need a dual by pass? what the point of the m
Old Dec 26, 2010 | 05:19 PM
you dont need a dual pass to have a h/e...the dual pass just moves more water
Old Dec 26, 2010 | 05:21 PM
DEZZIE41's Avatar
kk so what size exchnger should i use then
Old Dec 26, 2010 | 05:23 PM
s3 from zzp. i have the ottp one but it didnt buy it from ottp and i couldnt say no to the price and it was new.
Got Bewst?
No a dual pass designed for the coolant to spend less time in the intake manifold, thus keeping the coolant cooler. And you don't NEED a h/e and dual pass but it helps a lot if you are doing back to back pulls.
Old Dec 26, 2010 | 05:24 PM
DEZZIE41's Avatar
i got the money got one so i mid as well and the look good on the car lol
Old Dec 26, 2010 | 05:25 PM
like i said moving the coolant faster
Old Dec 26, 2010 | 05:32 PM
Got Bewst?
No you said it moves More water
Old Dec 26, 2010 | 05:38 PM
srt-10's Avatar
holy hell dezzie, you change your mind more then i do, haha. I went 2.8/60 with no cooling mods for most of the summer. Like everyone said, the car wont blow up, but it will heat soak faster and you wont feel the full power until you get some cooling mods. H/e will help, but i suggest get more cooling mods later one in the summer. I say get meth, that is one of the best mods you can get.
Old Dec 26, 2010 | 05:46 PM
Got Bewst?
This ^^^. Running meth/water mix will actually lower you're IAT2's and keep them there. My temps are 120-130 after a pull.
Old Dec 26, 2010 | 05:50 PM
same thing pretty much. just i said water and not coolant
Old Dec 26, 2010 | 05:55 PM
b00sted06ss's Avatar
how well does the 4th gen h/e work?
Old Dec 26, 2010 | 06:10 PM
srt-10's Avatar
that and it will allow for more timing. I was able to put my timing to 25* when i had the tvs and was only seeing 149* temps after 3 pulls back, to back to back.
im lowered and i tend to open up the drain valve while driving. i havent done any testing on it
Old Dec 26, 2010 | 07:08 PM
DEZZIE41's Avatar
soo prices add fast ya i do change my mind alot lol
