Major Problem!!!
Old Feb 3, 2007 | 12:44 PM
07cobaltss's Avatar
Major Problem!!!
ok i just removed the stock shifter out of my 07 cobalt. i ordered the B&M and i'm looking at the directions, and i dont think that the shifter for the 06 and the 07 are the same. the shaft on the 07 is a solid shaft, and the b&M instructions say to reuse some of the parts and they done seem like they are coming off.... HELP! any 07's have this installed or 06's i reallly need help here. i basicly hacked the other one apart, and i dont think its going back together.
Old Feb 3, 2007 | 01:30 PM
Ratchet104's Avatar
If you could take some pictures, I'm sure it'd be a lot easier to help you out
Old Feb 3, 2007 | 01:34 PM
07cobaltss's Avatar
well i guess my question is how do you get the drive cable hinge attached to the B&M blue ball? i found a white cap that looks like goes in the hole in the hinge and connects to the blue ball? but i cant the the mother ****** to press on
Old Feb 3, 2007 | 01:37 PM
LaserblueSS's Avatar
from the how to on this site for that install, i hear that it really is a bitch to get pressd on. just have to work at it. someone correct me if im wrong.
Old Feb 3, 2007 | 02:08 PM
07cobaltss's Avatar
finnaly got it on, but now i'm going to put it back in the car and i forgot to make the ******* refrence marks on the cables.... ****!
Old Feb 3, 2007 | 02:31 PM
NGalaxyTimmyo's Avatar
then it's gonna be trial and error. When I did my cavy way back when I didn't mark them, and I got it where I wanted it to be in neutral, and then adjusted the cables. Then try all the gears, and adjust as needed.
Old Feb 3, 2007 | 03:13 PM
tummy's Avatar
its the same as the 06 its just a pain in the ass
Old Feb 3, 2007 | 03:17 PM
07cobaltss's Avatar
ok next question is the Lock ring that does near the bottom of the shaft really needed? because i didnt use it... i got it all installed some areas are kinda sticky when shifting... but i'l make adjustments later when i have time... thanks for all the help!!!!
Old Feb 3, 2007 | 03:48 PM
CobaltSSilver's Avatar
Hey is the Hurst shifter an easier install then this?
Old Feb 3, 2007 | 05:42 PM
07cobaltss's Avatar
I really dout it. the installation is pretty much the same other then the solid bushings for the base of the shifter. Overall the installation took about an hour and a half. Just make sure you have the blue ball on the right way... i didnt know it was upside down till i hade it in the car and was lookin at it. personaly i love the B&M, i've seen the Hurst and dont really like it.
B&M all the way
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
