Makin' power!
Makin' power!
After running consistent 12.3s at the track on the 14th, we decided it was time to bolt on the new ZZP twincharge setup. The new setup includes a Bullseye Super 362 extended tip turbo and ZZP race intercooler. We had the car running Friday morning, but rain ruined our plans to hit the track. We did a little tuning on the dyno on Friday, running just under 400whp at 22psi with a conservative tune. We then got a little bit more aggressive with the tune and made 425whp at 23psi. On Saturday, we decided to start turning it up and got more aggressive. The final result was 489whp and 486whp at 30 psi with plenty left in the car. I am going to race the car about 425whp for the first few shake down passes and turn it up from there!
Mods include:
ZZP twincharge kit
Bullseye Super 362
ZZP race intercooler (with v-band connections)
Tial 44mm waste gate
Tial Q bov
ZZP turbo exhaust manifold
External waste gate dump
ZZP 650HP fuel pump upgrade
80lbs injectors
ZZP fuel pump rewire
ZZP boost reference
Cylinder Head:
Stock cylinder head
Stock cams
80lbs valve springs
Short block:
Stock pistons, rods, crank.
Balance delete
Cooling Mods:
ZZP electric water pump kit
ZZP oil cooler delete
ZZP single pass intake manifold
ZZP 15 row single pass heat exchanger
Suspension:
SSC lowering springs
ZZP spring blockers
ZZP tubular control arms
I will update my post after we race on Wednesday. I hope we get the chance to go to the track, the forecast is calling for rain Wednesday and Friday, but sunshine the days in between, but that's always how it seems to work. I will also try to get some pictures of the kit on the car for you this week.
Mods include:
ZZP twincharge kit
Bullseye Super 362
Tial Q bov
80lbs injectors
ZZP boost reference
Cylinder Head:
Stock cylinder head
Stock cams
80lbs valve springs
Short block:
Balance delete
Cooling Mods:
Suspension:
ZZP spring blockers
I would like to personally thank ZZP for spending all this time, money and R&D you guys are doing for these cars. Keep up the good work!!!! If I run into a big sum of money I will be giving you guys a call for sure.
Damn guys that's really impressive. I really want to see some 1/4 times on this setup. Like Eric said (red05sssc) if I ever get a ton of spending money, I'm coming to you guys to twincharge this beast.
It's the complete comtrol arm. They are made out of chromoly and the spring blocker limits the rear suspension. They are only used when we are at the track, not something I would want to drive around on.
yea boy!
wow..awesome **** .. i love the work you guys are doing.. this needs moar pics and vidz
however.. i already see one thing your going to get shift for ..
stock cylinder head? ummmmm
