Map Sensors
Map Sensors
Does anyone know if the baro or scip sensors are 2 bar. or is it just the map sensor.
I am going to use one to control my watermeth on my trans am and was wondering which one to use.
Thanks.C
Thanks.C
your TA wont have a SCIP (supercharger inlet pressure)
and a baro (barometric presser sensor) measures just atmospheric pressure changes.
is your TA boosted? if so, use map
if not, set it off TPS.
I am going to be running the sts turbo kit. I still have my progressive devils own water meth kit off the Cobalt and it uses the map sensor. I sold my old intake and left the sensor in. I still have the baro sensor so That is why I was wondering if it was 2 bar also.
an IAT sensor DOES NOT measure pressure, it has no "BAR" rateing.
same with the baro sensor, thats for atmospheric pressure only.
your MAP sensor is the key, 1 bar is required to read normal, day to day pressures. any boost amount requires the sensor to be set up to read above atmospheric.
a normal NA car will not have such a feature from the factory.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
