max boost on stock internals
Old Jan 25, 2008 | 05:50 PM
silversoldier06's Avatar
if i was to hook a boost controller up to my 06 ss/sc what would be the max amount of boost i could fron safely with complete stock internals...
Old Jan 25, 2008 | 05:51 PM
Area47's Avatar
Rent me! per hour
boost control is done by the pulley.
this is not a turbo car.
Old Jan 25, 2008 | 05:53 PM
Acidangel_5.0's Avatar
Old Jan 25, 2008 | 05:55 PM
splitimage's Avatar
you can use a boost controller to limit MAX boost, like for example putting on a 2.6 but wanting only 15 psi.
but with hpt i dont see why u would.
as for amounts u can push, a 2.5 gets close to 20lbs but then u need mad cooling to support it YO
Old Jan 25, 2008 | 05:59 PM
i understand that its not a turbo car i was just wondering if i was to start regulating my boost what the max i could push safely off stock internals...
im still running at stock boost but i was just wondering if i could raise it ne and what i could take it to and still be ok or would it run better leavin it where its at?
Last edited by silversoldier06; Jan 25, 2008 at 05:59 PM. Reason: Automerged Doublepost
Old Jan 25, 2008 | 06:01 PM
an0malous's Avatar
with the M62 in truth once you go above 12 psi it starts losing efficiency.
after about 15-16 psi its basically a cute little herman nelson.
its not the boost thats killing our stock internals, its the heat.
Area47's Avatar
Rent me! per hour
you can't raise it. you change the pulley to do so. there is a lot of factors that go into how much boost can be run.
Old Jan 25, 2008 | 06:02 PM
so its not really gonna matter if i raise my boost ne? without puttin a upgraded cooling system?
Area47's Avatar
Rent me! per hour
::confused look:: ok, you can run with this one
lol
Old Jan 25, 2008 | 06:03 PM
an0malous's Avatar
lol
you disagree that our little M62 heaton is what causes alot of the engine failures?
BlurpleSS's Avatar
hahahahahaha!!!!!
well to answer your question, max boost on stock internals IMO is 15psi with a stage 2 pulley. max for the supercharger itself is 20psi but I've seen blown motors from boost over 15psi so i'd stay away from anything higher than that.
Old Jan 25, 2008 | 06:04 PM
ah i c ...so i cant take it up ne without changin the pulleys regaurdless...? that makes since...im not puttin one on it was just a question that one of my buddies brought up and was wondering if it would work...i am thinkin bout the stage two at the moment, what do they s2's run on boost?
Old Jan 25, 2008 | 06:06 PM
Psykostevo's Avatar
If you put a boost controller on it (which you can) you would only be boosting at most 12.5 psi. You need to swap the pulley, in which case 17.5psi is what you can run safely. The gaskets can handle about 22psi, but your pistons can't take that heat from a 20k+rpm eaton.
Kibosh3's Avatar
ya...you can go down in pulley sizes, increases boost; creates more heat....lose max HP, gain more TQ
Old Jan 25, 2008 | 06:08 PM
Area47's Avatar
Rent me! per hour
um. wrong.
an0m. yes i do disagree.
Old Jan 25, 2008 | 06:11 PM
an0malous's Avatar
hmmm i dunno man. i know theres other things at play.
but i think its nearly impossible to dispute that the superheated air from an overspun M62 causes alot of problems.
care to elaborate? im always willing to learn more
Old Jan 25, 2008 | 06:14 PM
Raven SS's Avatar
the heat is gonna kill the supercharger not the engine...the boost is what kills our engine..to mucho yo
Old Jan 25, 2008 | 06:16 PM
firestorm's Avatar
waits to see Anom get schooled....
Old Jan 25, 2008 | 06:17 PM
splitimage's Avatar
the efficiency range is in the 14000 rpm range which is a 2.8 at 6800 rpm
someone like forever ago did a whole write up on it, im too lazy to find it. has nothing to do with boost
Originally Posted by BlurpleSS
hahahahahaha!!!!!
oh my what a dumb dumb
you couldnt be more wrong sir!
this engine can handle alot of boost, heat is a killing factor, or RETARDS
Last edited by splitimage; Jan 25, 2008 at 06:17 PM. Reason: Automerged Doublepost
Old Jan 25, 2008 | 06:19 PM
an0malous's Avatar
the efficiency range corresponds to around about 15psi.
i guess i should have quoted RPM values....but you know what i meant.
pumping 160*+ air into the engine causes problems.
hence why everyone is excited about the harrop blower swap.
effieciency ftw.
Old Jan 25, 2008 | 06:20 PM
Raven SS's Avatar
ur not gonna see more than 20psi with out 2 qts of oil all over ur engine bay..
Onyxd04Redline's Avatar
Past stock boost is even bad. People go straight for the pulley when they should be doing exhaust and intake mods first.
Old Jan 25, 2008 | 06:25 PM
splitimage's Avatar
the first valid thing ive seen u post in forever :P
Old Jan 25, 2008 | 06:41 PM
Area47's Avatar
Rent me! per hour
http://www.eaton.com/ecm/groups/publ.../ct_128484.gif
tell me what that says, and you will have an answer.
there is a way to overspin the blower well past it's efficiency range. most people do this with failed success. compressing air regardless of how many "psi" you run still creates heat. the stock efficiency of the m62 is 7 psi. this does not account for the after cooler.
does a smaller pulley produce more boost, horsepower, torque? yes. i have dyno sheets to prove this. does it also create heat?
**** yes it does. this is where people make major mistakes.
Old Jan 25, 2008 | 06:47 PM
Psykostevo's Avatar
Retards are the #1 reason these cars blow up. Anyone who knows what happened to the guy who bought my Cobalt SS knows what I am talking about. Too many people buy a car for the wrong reasons, and with a lack of experience or responsibility.
