mechanicle boost gauge
i installed my mech. boost gauge tonight and after 5lbs of boost it reads extremely erratic. also i never see 12lbs only 8-9 when its readable. i didnt use the line provided tho i used vaccum hose could that cause it?
the stock gauge is slow and has a lagto it (just like all the other gauges on the cluster). With my mechanical gauge, i can tap the gas very fast, and have my gauge show 5psi before the engine even makes a sound. I'll make a vid some time if you like...
i hit peak boost at any RPM instantly...and my gauge can actually show it. Thats all it is really
I can do a -20inHg to 10PSI to -20inHg probably faster than your gauge will show you getting to 10PSI
Just some info
Oh, they also look badass
Just some info
Sl0wbaltSS
Nov 21, 2018 11:11 PM
